AndyM
Has anybody experience the target charge level resetting to 100%. The first time I put it down to user error but it has happened again. It seems that it won't stay at 80% and periodically resets.
Let us know if you get a reply I never have.I have emailed MG customer service to report the problem.
Not now Mr Smart has thrown his dummy outLet us know if you get a reply I never have.
Despite showing charge limited to 80%, both in the car and on the app. This morning found the car charged to 100%. Had the car for 3 weeks, this is the first time I've seen this. ??
Thank you for your email, however your first port of call, should be your MG Dealership in order to see if this has occurred as the result of fault.
Please note that you will be required to charge the vehicle to 100% using AC charging as often as you can manage, in order to keep the battery cells equalised and balanced.
Yours sincerely
_______________________________________________________________________________
Gary Smart
Customer Service Coordinator
Aftersales
The requirement is for LR (I have a Trophy LR). It is the LFP battery tech that is more forgiving of being charged to 100% always. The LR needs to be charged to 100% periodically but it shouldn't override a scheduled charge as that can push the charging into peak rates. If the car thinks there is a need to re-balance then it should alert not just take a tenner out of my beer money.If you have a SR model isnt there a requirement to charge to 100% periodically? perhaps this is why it is changing to 100% sometimes. If it is a LR then it sounds like a bug.
Hi AndyThe requirement is for LR (I have a Trophy LR). It is the LFP battery tech that is more forgiving of being charged to 100% always. The LR needs to be charged to 100% periodically but it shouldn't override a scheduled charge as that can push the charging into peak rates. If the car thinks there is a need to re-balance then it should alert not just take a tenner out of my beer money.
