Temperature settings on Auto A/C
seasidersrus27
Hitchin, UK
Hi there everybody. I've had my trophy for a couple of months and I'm finding that the temperature setting on auto a/c seems way off eg 23°C setting feels more like 19°C in car at steady state. I've seen some references to this in other posts. Has anybody had this checked out by a dealer. Is it a calibration issue or software?
Mine's set to 27°C Auto normally.
I preheat at "HIGH" setting as the 10 minutes it runs for doesn't get the car warm if set lower.
I did a double preheat yesterday, High heat, both heated seats on, ran for 10 minutes then ran it again when it stopped. The car was well toasty. ☺️
I go for 28°C usually, but on sunny days I have to turn that down even if it's cold outside. I agree, it's not worth running the pre-heat unless you do it at HI. Which uses 2% of the battery in 10 minutes!
I have the same issue. Nissan Leaf wasn’t like it so not because it’s a heat pump then…
Thanks everybody for replying. Just set my a/c at 25°C and now basking in a warm car at last.....just in time to see the range drop off for the colder weather ?
I set my A/c to between 25 and 27 in summer, and now the temperatures have dropped, to between 21 and 23
I find in mine, the gauge is 3 degrees out. At an indicated 23 the cars interior is at 20C
    Votes: 985 77.5%
    Votes: 189 14.9%
    Votes: 97 7.6%
