Hi all. I am from Singapore and I am looking to get a MGS6.
I like to know from existing owners whether there are any aspects of the S6 that is quite unlikeable? In Singapore cars cost a lot of money so I'm doing research on this.
I am aware that this is an enthusiasts forum but I'm hoping for anything negative about the car ... sort of stuff that only real owners and not youtube reviewers show?
Thank you all!
Hi, I've had my S6 Dual Motor a few weeks and travelled 600 miles. It's charged to 80% in 0-5 degrees C overnight which gives about 180 miles of normal to occasional spirited driving. The car handles the 360hp well, and can take the lead in most traffic light gran prix with a satisfying surge of power, if that's your thing, but if you start to push it you become very aware if it's 2400kg with the stability programme cutting in early with a slap on the wrist before you ditch it. Imagine a how a powerful yacht performs, and that's it's characteristic. This car is much happier cruising about. That said it's very stable and capable in the bends, and overtaking is impressively quick.
There i
s nothing about the car which makes it "unlikable", it's the opposite. Very comfortable, quiet, refined, and drives well.
Every car has it's downsides, and so far I've not found any major issues. Most of the niggles are software related that could be fixed with updates.
Examples:
If you manually activate the 360 camera under 10 mph then select reverse, the software turns it off - really it should stay on.
Similarly, the side camera turns on at a stand still when indicating. This doesn't always work reliably when Android Auto is showing, and is a bit of a pointless feature. It would be better to show you the blind spot when driving.
The head up display is also good, and very useful, but for me it has a very slight blur to it. I can never get it quite right. Also it doesn't seem to adjust for each driver memory pre-set. At night time in the dark, if you have it set too bright you can see r light bleed from the edge of its screen reflecting in the windscreen.
It could be the current cold weather but the tyre pressure monitor is always flagging up low pressure in the morning. It probably needs the sensitivity adjusting.
The drivers seat could do with a pivot function at the axis so the front lifts and supports the back of your knee more if you're tall.
The electric mirrors do not always remember their pre set state pile the seats.. usually they, go wrong after reversing for some reason.
The stereo is good and holds a loud volume without distortion, but it's very bright sounding, which can make it sound cheap in some music. You can fix this by setting the bass to max and all other eq settings to mid range, then setting the high end eq to your preference.
Finally, I've not managed to open the boot by kicking behind. It's mentioned in the instruction video and there is a setting in the menu for hands free boot opening... maybe I'm doing something wrong.
On the whole I would recommend this car. It's a beautiful drive, lovely materials, nice to drive, very spacious, relaxing and goes like crazy. For the money, I'd say it's a good choice.
