Vingnut
- Nov 20, 2022
- Solutions
- 1
- Location
- Haram, Ålesund
- MG4 Trophy LR
I have sifted trough the forum for a way to get the MG4 ACC to not slow down in curves, or at least not slow down so much as the ACC drives me crazy. Here are my findings so far, tested a little bit on my MG4 Luxury and it looks prommesing so far. Maybe this is known to many here but not as I have seen.
As a note, MG4 ACC is taking its cues from the same settings we use to drive it without ACC engaged (Stupid), therefore the ACC is a right pain in the back when engaged when the car is set to Normal mode and standard settings.
If one want the ACC to not slow down/not slow down as much and speed up quicker when it slows down, try this.
1. Put the car in Sport mode. This make the car speed up quicker after a slow down.
2. Put the cars regen in Adaptive mode. This make the car behave not so harsh when it slows down.
Not sure if this is needed but I used theese settings today on a B road here in Norway and the car behaved quite ok.
3. Turn off LKA (Lane keep assist). This reduses beeps and nudging in the steering wheel when driving on smal roads, and make the journy smoother.
4. Set the distance to next car infront of you (ACC) to minimum (left on the left joystic in LHD cars). Not 100% sure what this does but my hunch is that it reduses unwanted slow downs for objects not there. Ofcourse this has to be adjusted when actually following another car.
Try this out and let us know if this is a step in the right direction.
