TPMS fault
Hello Everyone
I have MG ZS EV 2023 excited model
I have replaced my wheel to 19 inches from the original 17 inches. i have moved the tpms sensor to a new wheel 19 inches. it was working for 2 days. but after that, it said tpms fault on my dashboard. all 4 sensors are not detected.
any suggestion or comment or clue about the issue with my tpms sensor?
Thank you
more updates when I release the air from the tyre. the car tpms can detect the tyre pressure again but when I drove for 10mins. it said fault tpms again
Hello @N2STY
Yes i have set it to 2.8 bar. it detected it 2.8 but after i drove the car 1hr today still said faulty tpms
no sealant. brand new wheel and tyre with old tpms sensor
possible it detected different wheel size
One theory would be the wheel size tpms may not be in range of receiver but you've ruled this out as it's detecting changing pressure
So it sounds like the tpms isn't waking up two things wake up the tpms changing pressure and the wheels rotating think of it as a ball bearing in a tube when the ball bearing moves it wakes the tpms if the tpms is fitted 90° out the ball can't move up and down the tube therefore the tpms stays asleep
how can I fix it? I thought the wheel and tyre company knew to install tpms sensor :(
Of course I could be wrong I think the problem could be tyre shops are used to seeing tpms looking like this
But MG uses smaller tpms
So can easily be 90 out what you can try is make sure valve is not at the bottom of the tyre undo the retaining nut a bit so you can twist the valve 90 then Titan nut back up
Or re visit tyre shop they don't need to take whole tyre off just break the bead to get access to the tpms
thank you @N2STY I will try to undo the nut and twist it a bit. I will borrow my friend's Autel 508 to check if the sensor is alive
strangely the tpms sensor was working for 2 days after out from tyre shop
You know it's alive because it giving you a reading when you add or remove air
This is why I asked if they add a sealant to the tyres to prevent punctures (most sealants are tpms safe if applied properly)
Hello @N2STY
i am not sure because i was not beside the tyre tech when they put the sensor. even on brand new tyre and wheel they put the sealant
i will check on the weekend with the scanner tool. I need to go and borrow from my friend to see if the scantool can detect it
Hi All, my MG ZS VTi petrol 2023 is reporting TPMS fault , i have booked a repair with dealer , but dealer want to charge £162 per hour for diagnostic and report.
I got 2 question:
1) should i be charged as i bought this as a New car with 7 year warranty from same dealer.
2) can i get it checked else where ? , this car is on PCP.
TIA,
Seth
I got 2 question:
TIA,
Seth
Different parts of the car have different warranty length, some 1 year, some 7 and some in-between...
Call another MG garage and ask for repair under warranty, see what they say.
I got 2 question:
TIA,
Seth
A TPMS fault is a major MOT fail so it should be covered at least up to the first MOT otherwise the vehicle is not fit for purpose.
Just an update, i didn’t manage to get round to do the tyres before the weather got warmer, for some reason once we got above 5 degrees on Monday the system warning went out and is now showing normal tyre pressure- guessing it definitely was sub zero temp that caused it. Thanks again all
Are you aware that ambient temperature will affect your car tyre pressures. It can be a bit of guess work trying to decide whether to alter tyre pressures according to climatic conditions. Generally if the temperatures remain fairly constant for a period of time but have changed dramatically compared to a previous period it is worthwhile adjusting the cold pressure up ur down marginally. If it is just a temperature spike then vehicle operation should moderate the temperature change.
