davethomasson
- Nov 4, 2023
- Location
- Kalamunda, Australia
- MG4 XPOWER
New owner - does the car need to be unlocked to allow the charging cable to be removed?
Yes. You usually need to unlock to get that Zzzzit sound; that's the sound from a small motor unlocking the charge plug from the car's socket. Otherwise, anyone could pull out your charge plug.does the car need to be unlocked to allow the charging cable to be removed?
And it would also allow anybody to steal your type-II cable... No, thanksThey might do that so that someone else can charge, and/or save you from overstay charges.
Where is that setting in the app?You can unlock just the cable rather than the whole car (and switch everything on) via the iSmart app.
Is it next to the start charging button under charge management?Where is that setting in the app?
Yep, that's it.Is it next to the start charging button under charge management?
