Vandalised chargers
An update to post #22,
The cables were replaced a couple of weeks ago, the operator has now increased the security arrangements for the cable by adding a DyeDeFender system. This consists of a pressurised stainless steel flexible pipe fixed to the cable, contained within a cover.View attachment 41212.
I found a video of the system in operation
Brilliant! Love it. Instant Smurf. 🤣🙂👍
There's always the option of one of these strategically placed, and activated when the cable is cut. 😉
High tension overhead cables are made of an aluminium alloy ( but they are stiff, inflexible ) . There must be an alternative to high value copper , I am not up to date on my metallurgy knowledge but a flexible aluminium based cable would seem to be the way to go.
An alternative would be to have a fixed protected post in a standardised position with a socket, and you plug your own high capacity short cable ( various lengths available ) which you carry around in the boot should you do a journey that requires it.
That's the DieDefender rather than the DyeDefender!
Nah... just need to have a 150kW wireless charger 📶📡
They could take a tip from the cash industry, Cash transporting vehicles are rarely big steel boxes. They are normal vans etc, but with a lining that makes it almost impossible to cut through. It's made up of all sorts of fibre/metal strips that pull out in saw blades/angle grinders and jam up the works.
The trick is to know that if somebody wants it enough, nothing you can do will stop them taking it. What you can do is make it too much hassle, too time consuming to be worth the effort. It should be a lot easier to do that for a low value cable that for a pile of cash.
I can't see the high pressure ink spray thing being workable, costs too high, probability of something going wrong too high, adds a lot of weight and awkwardness to charger cables which are already hard enough for some people to use.
We sparks are dreadful on the forum I frequent.
A poor hapless DIYer will come on asking an innocent question and soon it will be off topic with several qualified sparks who are supposed to be offering advice arguing amongst themselves about this switch or that circuit or such and such a regulation.....!
And yes, slap my wrist, I didn't help with that contribution...
The offenders could be caught blue-handed!
It's also possible that they'll get wise to this, and discharge the pressure with something before the actual cut. But I imagine it would still be messy.
I wonder how fiddly they are to install, and how UV resistant the plastic is. And how resistant to accidental cutting by jewellery. It would take some engineering to get this sort of thing right.
