NLMGSAN
- Dec 26, 2023
- Ede, NL
- MG4 (2022-2025)
Is this hum constantly present? Or does it kick in at a certain speed?
Interesting ,do you know the build date of your Trophy?Strangly enough, there is hum in my Trophy ER as well. Kicks in at around 64 mph (105 kmh). I wonder if its the tires, or somehing else.
Does it? Or is that a rhetorical question siteguru?Trophy ER has the same rear motor as the X-Power?
No. Mine was delivered end of december. But this model was exported to Europe together with the XPower.Interesting ,do you know the build date of your Trophy?
Do you know the build date though? You may have got it in Dec 23...but it may have been sat in a lockup or field.No. Mine was delivered end of december. But this model was exported to Europe together with the XPower.
No certificate here. But I will check.Do you know the build date though? You may have got it in Dec 23...but it may have been sat in a lockup or field.
It does tell you on rhe certificate of conformity, or a sticker under the parcel shelf.
Rhetorical? Don't know - but I know the ER has a higher power motor vs the LR, and wondered if the XP used the same rear motor (as well as the extra front motor). Info previously suggested the effect may be due to a drive shaft issue on the rear motor, so if the ER and XP use the same rear motor assembly then that could explain why some ER owners may observe the vibration.Does it? Or is that a rhetorical question siteguru?
That could be. But than more ER owners must hear and feel the hum and vibration.Rhetorical? Don't know - but I know the ER has a higher power motor vs the LR, and wondered if the XP used the same rear motor (as well as the extra front motor). Info previously suggested the effect may be due to a drive shaft issue on the rear motor, so if the ER and XP use the same rear motor assembly then that could explain why some ER owners may observe the vibration.![]()
I had a Road Force balancing and alignment myself as well. Based on that they replaced one tyre (right rear). Right front was also poor but less severe. MG refused to replace that one.For me its strange that eco removes 80% of the vibes. I go to any other mode and its back. Sports mode the worst. I have had full balance and alignment done, private not by MG. Wheel balance and alignment way out , bad bad from factory. this week MG are doing a road force balance for some reason, ill take that for free , it wont fix it. Ive called them out before hand as a complete waste of my time and a stall tactic. None the less i have to respond to all attempts to fix it, in prep for court.
I do not use FB. Is this about the ER? Or Trophy in general?Well a strange coincidence, some Trophy owners have started to post on FB today
So my appointment this Friday has been cancelled as apparently, the 'new' damper is now out of stock at MG UK?!So just been contacted by our dealer to say the 'revised' steering damper is now available to order and they are hoping to fit it to our car next Friday.
I spoke to the master tech and he confirmed that new damper is a different part number to the previous damper (which we all know did nothing), although as he hasn't seen one in the flesh yet, he was unable to talk about any differences.
As discussed previously, the best this will do is slightly mask the problem, rather than address the root cause but I'll report back after it's been fitted with my findings anyway.
Rebooked for 4th October then got a 300 mile motorway trip on 11th so a good chance to evaluate.
