Warning Sign ⚠️
For me it's "Low rear left tyre pressure" most of the time. At around 0C the sign is gone but at -8C and below it's back.
You need to put a bit more air in the tyres, so that the normal pressure fluctuations with low temperature don't take them down below the warning threshhold.
Tyre pressures need adjusting as the seasonal temperature changes and should be checked once a month with a pressure gauge.
The tyre pressure sensors are there as a safety feature to indicate if a tyre is losing pressure during a journey or since it was last checked not indicating with a yellow warning that they need checking.
I guess I learned routine car maintenance when car's suspension and king pins needed regular greasing every 6000 miles so a quick check of tyre pressures, regular washer fluid top-ups, lubricating door hinges and stays etc. is second nature.
Rant over ?
Rant over ?
Ian, we are not stuck in Victorian times! My robot takes care of the car, including the driving. My other robot maintains the car robot. You'll be telling me you cook your own food next! ???
(Oops, sorry, posted from 2050 by mistake!)
    Votes: 987 77.6%
    Votes: 189 14.9%
    Votes: 96 7.5%
