fx860e
I know I’ve mentioned this in a previous post about the 12v battery having a repetitive 9-10A draw on it every few minutes even though the car is off, locked and just sitting on the drive. I’ve also been puzzled at the constant warnings for ‘Low 12v Battery’ I get when I’ve left the car standing for a day.
So, I purchased a Bluetooth 12v battery monitor and left it connected while being locked in the car for 48 hours.
I’ve included pictures of the results which confirms that even though the car is disconnected from Wi-Fi, and the keys are placed in a Faraday case, the car 5 or 6 times an hour draws about 10A for a minute or so, and then slowly tapers down to about 250 to 500 mA, before doing it repeatedly again for no apparent reason.
This draw, even after a few hours, makes the car sleep, with the effect that it disconnects from the MG iSMART app which our Scottish Power need to communicate with the car for overnight charging.
To explain the pictures.
Picture 1 Noon to Midnight.
I connected the 12v battery to a battery charger for an hour (11-12pm) and disconnected it at Noon. Immediately you can see the draw and recovery 5-6 times an hour, for seemingly no reason.
Picture 2 Midnight to Midnight.
Picture 3 Midnight to Noon.
At 11.85volts the draw stops, flat lines. I kept it connected for a few hours more and nothing further happened.
Picture 4 at 14.45pm
I was relived to find that I could still open the door with the key fob. After putting a clamp multimeter around the 12v+ wire I turned the car on. (PHEW! everything worked.) I saw the car immediately throw a 60A current into the 12v battery which you can see in the picture.
Picture 5. (Wasn’t expecting this.)
After a few minutes I turned off the car and connected the wall charger and was presently surprised to find that the 12v battery gets charged from the wall charger, so no need for a 12v battery charger. I turned it off and on again to check but at 14.50pm the car main battery reached 100% and both of the battery's stopped charging .
I hope some of you may find any of this helpful and that it may explain what’s happening, if not why…
