EVentropy
If you not into how 100+ cells are managed, don't read as somewhat OCD.
I discovered this some months ago but the car performed fine and I was too busy at work to pursue.
I recreated as I didn't save and I have booked my first service, this is as good a time as any to ask the experts.
Last night charged to "100%", balanced per usual, didn't drive for 15hrs.
Did our standard "blow off the top" tonight , by driving on flat for 1km, up the hill ~150m (vert), back down and a couple of km's on flat. Plotted V vs time.
In addition, I've established previously, via OBD & car scanner, that charging terminates with highest voltage cell at 3.66V, and balancing begins. Delta at this point is ~360mV. I have what this in detail . (real time roll over) Reducing SOC by driving to 98% gives ~10mV delta. El cheapo balancing by inherent characteristics of LiFePO4?
7kW charging power diminishes reasonably quickly approaching end of charge/start balance, as would be expected, to 3.6kW at termination to balancing. 3.6kW/350V=~10A which = 0.07C (for 51kWh ) using 350V as nominal. This conforms to std charging practice for LiFe. Shunt based termination is common on higher end stuff.
At termination of balancing, highest cell to lowest ~130mV.
Start of drive SoC still 100%, Delta 108mV. (22mV blown off resting after balancing)
Plot of highest cell voltage and lowest cell voltage vs time.
Expanded time axis for rapid acceleration hill climb
* Is cutting off charging with first high cell hitting ~3.65V, the way SAIC have designed this?
* Is cutting of balancing at a delta of ~130mV normal for MG4 LiFePO4. Why not 10mv, or zero, or until next highest is 10mv?
* Is a voltage sag to 2.9V under load of lowest cell within the parameters for a supposed close to 100% SOC'd cell acceptable? It seems to me that
that the lowest cell here is no where near fully charged and the high cell is not lowered enough. So balancing is not functioning correctly. (Tip hat to T1-terry.)
* Is there any proprietry software that can monitor individual cell voltage in real time via VDI , SIPS etc, as being able to detect highest & lowest?
Current plot would suggest that individually they are monitored as opposed to per module.
* The above suggest that "100%" SOC is governed by how far you bring down the high cell(s) so you can continue to bring up the mean pack voltage without
retripping the HV cutoff. So it is wholey up to the balancing parameters and sophistication.
*Recent Capacity test from 100% steep climb from sea level to 500m , descend to sealevel, drive mild hilly route for 115km. Repeat in reverse. 230km total with 28% left,so ~300km per charge.
* Second plot 39:20 has 70mV delta. At 39:28 with lowest charged cell max sag, delta is 120mV. I'm going to repeat this at 20% SOC and see where the sag gets to
and what happens to delta; and min V, within safety spec or lower? I assume there is no bottom balancing facility as car is rarely used there.
Any input welcome!
