I don't suppose that MG5 bracket and the cover could be adapted to the ZS to make it quieter?Here's mine, works a treat.
More space there than I would have thoughtHere you go with the pics. Thumbnails as I didn't reduce them.
View attachment 6081View attachment 6082
Extremely unlikely, it's moulded to the shape of the mg5 void.I don't suppose that MG5 bracket and the cover could be adapted to the ZS to make it quieter?
It makes no noise difference without it fitted, it was only seeing the ZS-EV without one, that made me take mine off.I don't suppose that MG5 bracket and the cover could be adapted to the ZS to make it quieter?
Just fits in the gap, it has no where to goI'm a bit on the fence. I like the idea of using the space, but taking the cover and frame off and exposing all the bits and pieces sounds a bit risky to me. I would be worried about invalidating warranties etc. I'd definitely be up for getting a frunk unit that could be put in - if that ever becomes a option.
@Bogrole - is that plastic box fixed in any way, or is it just sitting there?
Nothing gets above 30 degrees C@Bogrole - yes, but it must sit on top of the gear in there - nothing that will heat or that might be fragile?
The bracket is very weak plastic! Take the cover off and have a look.It looks like you are leaving out the bracket which goes front to back - is that just to screw the cover to, or could it be strengthening?
I quite like the idea of sticking the (rarely used) cable somewhere other than the boot. I also have the granny cable taking up a side pocket, which I am unlikely to ever use so I'm inclined to pout it in the garage, but who knows when I might need it in an emergency when out and about.
In my experience, just drops in, and no rattling, at least from where I sit.Haha, I will then!! But if that's the case, I'm warming to the idea.
How do you stop the box rattling around?
