Wheel arch cut outs
Roddyrat
Lichfield
Cyberster
Hi. Do the cut outs in the front wheel arches under the bonnet serve any purpose or can I safely cover them in ?
I've also wondered if they serve a purpose. For example, some sort of aerodynamic function to aid air flow from the front air intakes into the front wheel arch?
Hi, I asked the dealer here in Thailand about the openings near the front shock towers and they assured me they were not meaningful. :unsure: I then confirmed with MG Thailand and was told I could cover the openings without issues. So,,,,,I cut some pieces from 3 mil rubber sheet and used silicone in about 6 small beads to secure them. If it becomes necessary its easily removed. But,,,,its odd that MG and the dealer seem unconcerned. Opposite these open ports on the underside of the hood (bonnet) 😊 looks to be a rubber diaphragm of sorts related to the holes? It looks like these are purposely arranged over the open ports. The openings themselves have a foam rubber type stripping around them to keep mud out when the bonnet is closed, however it clearly doesn't work. Apparently I have it on good authority that I'm free to cover the holes without repercussion. 🤞My solution works well keeping the surrounding area free of mud and debris. I also haven't noticed any adverse effects. :cool:
Looks great, however a lot of dirt will accumulate underneath.
I keep mine open and clean.
A removable solution would be perfect, same like the other covers.
I guess MG will come up with something on a face lift soon or later
If you had aligned the straight line with the subtle curve, it would have been absolute perfection!
Was the plastic panel the same colour as the car, or did you repaint it yourself?
I'm not that much of a perfectionist. It's under the hood and I don't have to look at it all day.
The plastic plate was available in the right color.
The bays covered with plastic probably to protect components from excess dust and dirt. Doubt it's cooling anything there. If anything its creating an air bubble under the hood. If it wasnt covered id agree with cooling
I think openings are for upper controlarm incase that it moves full travel in major bump on road. I covered edges of opening with foamrubber so dust and dirt wont fly under bonnet.
