Wheel trim top coat peeling off.
let us know the outcome of the whole warranty issue . good luck
So I finally had the car in for service and they have agreed to replace all four hub caps (wheel trims) under warranty Special note to anyone experiencing the same… point out that pressure washer would delaminate from the outside first, not the middle of the clear layer outwards (which is what they actually do)
View attachment 28190Has anyone experienced the clear top coat peeling away from the surface of the wheel trims on ZS ev. I'm very disappointed that MG has declined this as a warranty claim on a two year old car.
Yes, the plastic wheel covers on my 2 years+ MG ZS EV are also peeling. Have you found a solution to replace the covers or removing to show the alloy wheels underneath?
Yes, the plastic wheel covers on my 2 years+ MG ZS EV are also peeling. Have you found a solution to replace the covers or removing to show the allow wheels underneath?
I haven't pursued it any further with MG. Every time I wash the car a little more of the film comes off. Eventually it will all be removed, at which point I will re coat them with a clear lacquer.
Same problem on MG4 trophy (20k miles), rubbish trim, thinking of replacing with new set of alloys, but cost could prevent this, any pointers where I could get a set?
