Joningy
Haven't got to the stage of employing a foreign nurse in a home to do it yet.We all have a rear wiper. It is just a question of whether you have a mechanical device to do it for you...
Good effort @gvgaut, but other folks here may not be as handy at DIY.With minor modifications the Bosch H281 (11 inches) works very well. I needed to use a dremel to take about 0.5cm off the end, and made the hole in the centre section of the slightly larger (you can use the original to get the size right) so that it fits snugly in the arm and flat to the glass. Finally I used a small amount of superglue to make sure that the blade doesn't pop out (where I took a small piece off the end) but now I have a blade that reaches just under the rear light in the middle and usage/coverage is perfect.
OK, I'll try and explain a bit more @TimothyN .I'm really sorry @Joningy, but I don't understand the mod "as shown". You show pictures of the spindle, but the part you recommend is just the blade, so, presumably, the arm remains in place.
Please help out the stupid among us with a simple explanation of what we buy and what we do...
I'll post it again here @TimothyN, I've already posted in 2 places here, 3rd time lucky!I am obviously too stupid for this. I don't understand whether you bought a new arm or not.
Does "Just the blade is required, but you can also buy a blade with an arm, but as the required mod is fairly straightforward, that's the route I took." mean that you bought the arm, or just the blade?
When you say "As the picture shows (thank you @MG Clive ) a small amount of the rectangular hole which the arm fits into needs lengthening by a few mm's to enable a proper fit"
I don't see a picture from either you or @MG Clive showing a rectangular hole that needs expanding.
I'm beginning to wonder if there are posts on this thread I'm not seeing? I'm not usually this dim.
Great, you probably won't want to cut out as much as I've shown, that's for information onlyThat now makes more sense. Not quite as dim as I felt! I have ordered one from Amazon, thank you!
Great @TimothyN , pleased it worked out!Thank you, I followed instructions and it's perfect. I'd say you need to take off only about 1mm. 2 max.
If you look carefully at the thread I posted , you will see the blade I used is.This is great tip to increase the size of the area cleaned by the rear wiper !.
For anybody who is looking to compare the original factory blade length, to the Bosch H281.
The Bosch H281 blade length at £5.99 is 280mm ( 11” inches ) long according to Amazon.
( not the 250mm as mentioned above ).
This is not the best fit for the rear wiper on MG4 AND MGS5, the best fit is Bosch H252 at 250mm, being just 250mm long and needs no shortening, just the minor alterations to the hole which the arm fits into.This is great tip to increase the size of the area cleaned by the rear wiper !.
Sorry, but why am I getting confused here ?.Good effort @gvgaut, but other folks here may not be as handy at DIY.
The Bosch H281 250mm blade I bought fitted perfectly, with the very slight mod as shown and now covers the rear dashcam area without the need to alter the length, hope the superglue doesn't mind rain and frost![]()
H252 is a best fit @250mm long, H281 is too long by 30 mm and requires the end being reduced in lengthSorry, but why am I getting confused here ?.
In this post above, it appears that the part number quoted is the Bosch blade recommended is the H281.
The spec of this part number blade is 280mm in length ?.
