Satal
I've had an MG ZS EV since November, one of the newer models. I think it's commonly referred to as an mk2. I also have a Zappi 2 (untethered, though I don't think this makes a difference).
I've been happily using the Zappi to charge the car overnight. However, now that we are starting to get some sunshine during the day, I'm getting enough excess solar (>1.4kW) to do a bit of charging from that.
I have the Zappi set up on Eco+ at 100% Green which I believe that it should only charge when the solar is producing excess, which I can see the excess being exported in the myenergi app.
The problem I'm having is that my MG won't automatically start charging when the Zappi sees excess being exported (over 2kW of excess for over the 30-second wait time). I need to start the charging manually in the iSmart app.
Even when I have manually started this through the iSmart app, the MG will stop charging after a short while (5-10 minutes), however, I'm assuming that might be caused by the excess briefly due to a cloud or me putting the kettle on. If I go back into the iSmart app and start charging again, it works fine until the next time it stops.
For the avoidance of doubt, the Zappi charge is unlocked for all of this, I made that mistake a couple of times when I first got the car.
I'm wondering if anyone else has had the same problems getting Eco+ charging working, and if so, whether they were able to get it to work?
I think I've seen on here, talking about the Mk1s needing a firmware update for the car for this to work but I haven't seen anything about this for the Mk2.
Thank you for any help or advice anyone is able to provide.
