Zappi charged delayed
If you have a zappi 2 why not try using the octopus go intelligent tariff; it gives 6 hours cheap rate at 7.5 p/kWh.
The octopus software works well on my early SR MG5.
Just one point on charging if you use Octopus Intelligent go when you set it up the first time make sure the system knows the battery is the 61Kw version. as the software works on % 10 % = 6.1Kw
if you use the setting for the older car that would be 5.3Kw for 10%
