Yandards
Been running 6kw of solar with a DC coupled battery plus a Zappi, Eddi and hub for about 18 months, on Octopus Got and an e208 so happy with the work around to stop the DC coupled battery (which is not visible to the Zappi as you can't use a CT clamp for DC output) being drained most of the time.
All charging is currently managed Zappi side as the app works unlike the Peugeot one for timed charging in-line with Octopus Go, it's a bit manual as I'm going in and guessing charge rate versus battery % to get it to around 80%.
Couple of questions for those with a Zappi and MG4:
1. Does the MG4 lock out the charger after a number of cycles?
I get 5 resets in the E-208 before it prevents anymore charging, as ECO+ runs at 100% (or it starts being supported by the home storage battery) occasional cloud cover over 30 seconds (this is a setting within the Zappi to hold charge for a period) causes the charge to stop. Once I've got over around 1.8kw of generation (1.4kw required to start, export margin set to 50w brings that to 1.45kw and around 300w of background household use) it'll kick back in.
2. I assume setting a charge limit in the car software isn't tied to a charge cycle, ie can you just set charge to 80% and no schedule for the charge?
