10-100% charging
Amun
Norfolk, UK
MGS5
There is a thread in the MG4 section, which suggests that 10-100% charging is required every so often - apparently this is mentioned in the MG4 manual.
I can't find anything in the MG5 manual that suggests that this is necessary - only charging to 100% and allowing equalisation to take place every so often.
So - is it necessary?
Hi, I have an SR Excite and charge from anything between 30-50% back up to 80-85% and monthly to 100% to balance the cells.
I haven't seen were it says the 4 need to be done from 10%.
Page 295 of the MG4 manual - there's a thread in the MG4 section, as well
Actually, it does say the same on page 244 of the MG5 manual, as follows (my italics) :-
"When using the vehicle on a daily basis, it is recommended to fully charge it at least once a week, which is conducive to the health maintenance of the high-voltage battery pack; every 3 months to half a year, a low-power (less than 10% or 1 grid) full charged is performed"
I missed it as I was looking under Equalisation, not Maintenance
Fully charging yes but 10% to 100%? no. If you charge your car on AC (at home usually) once a month or so to 100% you'll be fine. To be honest unless you are doing a massive amount of DC rapid charging you'll not notice any difference.
This has nothing to do with cell balancing, rather this procedure is required to measure and update the battery’s capacity (SOH).
But why would they put it in the manual if it isn't required?
Indeed it is, and it is a standard maintenance procedure for basically anything with a rechargeable battery, such as an EV, mobile phone, or laptop.
