macke
My MG4 Trophy reloads the contents of the USB stick every time I get in the car. Why doesn't it retain it? I have about 600 tracks in folder by artist. Once loaded it seems to work ok, but it 5 minutes to load.
My USB is in the Right Port.
To be accurate I have a multiport adapter plugged (USB C) and then the flash drive into one slot.
It just works like normal, except I have to use a USB C to A adapter.What happens if you remove the multiport adapter and just install the flash drive?
It just sees it as another FolderI have no idea if the car can correctly handle more than one device plugged into the USB C port as a multiport device will report itself as a hub device with more or more other devices attached.
Also I'm not sure how much power the USB C port can provide, which could be another problem.
