Android Auto is it rubbish?
Walespete
Age
65
Llandudno, Wales, UK
Hi,
Android Auto connects reliably and it comes up on my MG4's display. I select the app I want and it loads fine.
However, I have no control of whatever app is running. The steering wheel buttons do nothing, nor does tapping the controls on the display. If music is playing from my phone I can stop and start a track but I cannot change that track.
Is this normal or am I doing something wrong?
If I'm playing music via Android Auto then the right joystick controls the media ... up/down for volume and right/left for Next Track/Previous Track. Press in for Play/Pause. (I use the Musicolet music player app). This works whether or not AA is actually using the screen ... if I'm at the Home screen then the Media panel shows the source as being Android Auto.
On my car the joystick controls do nowt. Nor does tapping the previous/next buttons on the car's screen. I can pause and play though.
Something's wrong then ... I'd suggest deleting any AA profile on the phone, and deleting the Bluetooth connection with the car (on the phone and in the car), and starting over again with the AA setup.
AA (and Apple CP if you have an iPhone) are so superior to the car manufacturers* satnav systems it's bizarre to me why people even bother trying to use them.
*There's a few that use Android Automotive with the Google maps interface "natively" such as Polestar and the Tesla system is excellent, but otherwise forget it.
That'll only change the interface method ... if there's a fundamental AA config issue on your phone then you might still encounter the same issues.
have you tried another cable or even the same cable inserted the other way around (if its USBC)? I had a cable that would often disconnect after 10 minutes, or sometimes not respond to screen touches, but a different cable fixed all those problems. The only issue I get now is if the fluff has built up in the phone's USB socket which causes a dodgy connection.
    Votes: 985 77.6%
    Votes: 187 14.7%
    Votes: 97 7.6%
