BOB353
- Nov 13, 2024
- Baldivis Western Australia
- ZS EV
Haven't tried it yet, was busy having my poppa napCaveat - the MG4/ZS links talk about the refreshed model ZS that we don't have in Australia - the MCE.
Looks like the 2024 ZS MCE and MG4 have identical software, whereas the MG ZS from 2022+ in Australia has something else... but, I guess you'll find out!
The earlier ZS (Gen1) has the 9" screen and you use the NaviEExtra method to update the map, placing a blank USB into USB-A port, the head unit writes data to the USB which includes details about the HU that pertains to only your unit, probably the HU serial number.
In 2022-2023 they went to the Gen2 which has the 10.0" flat screen so if this is what is in the MG4 I would guess it is the same unit so there is a good chance the maps will work as long as they are for this region.
Be back shortly after I try it.
Well, that was easy, I now have it working again on this version "
23Q4_ANZ_20240115233205 1176101301" so I now longer have a bricked navigate function.
Now to try and get some newer maps, a quick search seems to indicate there are no newer maps than 23Q4 which is newer than the maps you listed in you opening post -
Map Data Version:
HERE_ANZ_21Q4 202112231738.
If I was you, I would do as I have done, they are 2 years newer than what you have.
Have a look here on how to do it - MAP DATA UPDATE FOR ZS EV LUXURY EDITI
Thanks for the head up, it would have saved me many hours and lots of money if I found it hay back when.
Mind you, it has kept me amused.
