Auto Hold has stopped working
AlfC
Penicuik
We have had our MG4 SE LR since March and our experience of it is overwhelmingly positive. The deep press on the brake pedal to hold the car at traffic lights has been a very nice addition to the convenience of driving the car so when it just stopped working a couple of days ago this was a big annoyance. I found the place in the menu where Auto Hold is an option (I never noticed it before and assume it defaulted to on) but no matter what I try it stays grey and refuses to switch on. Anyone else had this or found what it takes to re-activate it?
Have you tried switching it on sitting in the driver's seat and after you've pressed the brake pedal?
Yes, just to make sure I went out and tried that again but no joy.
Does one pedal driving disable it?
I don't have one-pedal driving. Does that appear in later firmware versions?
Could you post a video so we can maybe figure out if indeed you are trying to enable it when car isn’t fully initialised?
I had this yesterday, drive into my drive, pressed the auto hold and a second later it disabled and the car crept forward… i had the same issue that I couldn’t toggle it back on so reset the infotainment unit which cleared it. My only other evidence was earlier in the journey I had the phantom AEB issue at a roundabout, fortunately no one behind me… scared the ? out of me… I wonder if that confused it
Thanks, now wondering if I unplugged the seatbelt befor applying the park button…. Update.. just tried this and the auto brake stayed on when I released my seatbelt, I tried opening the door too and it gave me a warning and applied the park break … so that’s good to know
Thanks all, it's working again. I tried the whole start up again as if I was about to set off and just before going to Drive I touched the slider in the Safety screen and it switched on! I powered off and tried again but without putting my seat belt on and it would play so that was the difference - seat belt on before making alterations. Now I think it comes on by default when I power up. I must have switched it off accidentally recently while aiming for the Power Off button which is on the same Safety Screen.
Thanks again for all your suggestions
Yeah, I've notived a few options are only changeable when you are sat down, strapped in and ready to go in Drive mode. The whole LKA menu on/off option in MG Pilot only appears on my car in this state too. I've read Autohold and One Pedal Drive do not work in reverse gear even when turned on so something to bear in mind.
Yes - look for READY in (P) before making changes to settings and everything that does stick should then stick.
Yes autohold only works in (D), forward mode.
Quite a lot of detail about how the auto hold and other systems work depending on sequence of events in this video - especially when opening the door and having the seatbelt latched or not
That's a very thorough walk through - clearer than the manual I think
My One Pedal driving mode wont switch on even when the battery is below 90% I am getting the not enough etc etc message and battery is now at 68% - software issue ? SE SR
Rob
    Votes: 1,068 77.7%
    Votes: 208 15.1%
    Votes: 99 7.2%
