Battery degradation
fatih
İstanbul
My car has covered 67 thousand kilometers (model with LFP battery) is this normal?
According to the forums, SOH is mostly a calculated value, based on -0,01%/day formula and not actual degradation...
Maybe someone can confirm, if SOH resets itself to proper value, if car is 100-0-100% cycled?
... mine has done the same Km's, and has a similar SOH with CarScanner (its linear with time / distance) - however the dealer says its at 100% - I have a LFP setup at home (ESS), of similar age, and that has much greater stress each day and that is at 98%. I've been keeping a eye on my home ESS and that seems to balance the cells within .01%, but if you dont charge it upto 100% each month, it sort of looses what the max capacity of each battery module is. So on my home system, Ive set it to charge to 100% every month, to reset everything - I suspect the MG4 does something similar 🤷‍♂️ 🤷‍♂️
16k miles, 2 years old, trophy 64kw, Car scanner has just dropped SOH from 99.2 to 98.7… only charge to 100% once a month….so feeling happy about that
    Votes: 1,082 77.7%
    Votes: 208 14.9%
    Votes: 103 7.4%
