Yes it is
@JodyS21 .
I have spoken about this earlier in this post.
This can be seen easterly this way.
While the car is standing still in the fully booted mode, press the footbrake down slowly but firmly.
But apply pressure making sure your right foot is placed over to the RIGHT hand side of the pedal foot plate.
As you feel your foot sink, just BEFORE your foot has come to the point where brake pressure / resistance can be felt, the outside of you foot wear WILL touch the “GO” pedal slightly earlier.
In effect, your foot wear will be contacting both pedals together.
As we know, EV’s are very responsive to even light pressure on the “GO” pedal.
So, in this condition the car wants to speed up, just before the point when the foot brake would be applying good pressure to the foot brake, in order to slow down the car.
The bigger your foot size or foot wear, the easier this is to reproduce.
If you apply foot pressure directly to the centre section of the footbrake pad, then there is no problem of course.
Try it for yourself and you will clearly see my point.
Do not attempt this while the car is in “DRIVE” of course !.
I can hear?you now ….. “Arhhh …. I see what he means now ?”.
I don’t think it’s a complete design error, more of a driver foot placement error I guess ?.
If the contact pressure point for the footbrake was slightly earlier, or the “GO” pedal contact point was latter, then it would not happen, due to the bigger over lap.
So I guess it could be ( like most things ) be improved.
If the OP had been unlucky enough to experience this condition on the day of his accident, then this MAY just go some way into explaining what happened.
A bit of a “Perfect Storm” of events ????.
