Car locked with the key inside...
You shouldn't be able to lock yourself inside the car - with or without the fob. The door handles should act as a manual release.
Yes, there was a software issue in the early days where this exact scenario happened, but MG issued a recall notice to get all cars updated to resolve this. (It was raised as a safety case with the DVSA in the UK).
When was the recall? I left my wife in the car to get something from a shop and she couldn't get out of the car. none of the doors would open, nor the windows.
73 reg x-power.
I always put my key in my trouser pocket, so far, I've never left my trousers in the car when I've pressed the lock button on the door handle. :rolleyes:
Sounds like you've been taking a leaf out of @Rolfe's book ;)
...keep up at the back, Terry :)
The same thing happened to me with my Luxury R46/22 "Trophy".
I opened the trunk and left my backpack with my smartphone and key inside, closed it, and was left outside. I couldn't open it.
If I pressed the handle to unlock the car, the alarm went off, and I had to go back home for the spare key.
With the latest R67 update, the same thing happened again, and now when I close the trunk, it opens automatically and prevents the vehicle from locking with the key inside.
I’m joining the club! I had an appointment after work so put my work bag (with my keys in there) in the boot which opened as expected without unlocking the car. Then I shut the boot, the car locked itself, I walk to the driver door and press the button, nothing happens. I swear under my breath as I remember this thread. Tried the boot, of course the alarm starts blaring, thankfully the app then let me cancel the alarm and also unlock the car.
I’m was a little surprised the car decided someone trying the boot was an attempt to illegally gain entry and worthy of notifying everybody in the neighbourhood.
I wonder if this is a fault or just a limitation of the system. It sort of has to lock the boot even though the keys are detected nearby, otherwise you couldn’t close/lock the boot whilst standing next to it. But perhaps a way to detect keys on the inside of the boot would’ve been a good addition.
¡Me uno al club! Tenía una cita después del trabajo, así que metí mi bolso de trabajo (con las llaves dentro) en el maletero, que se abrió como era de esperar sin desbloquear el coche. Luego cerré el maletero, el coche se bloqueó solo, fui a la puerta del conductor y presioné el botón, pero no pasó nada. Maldigo en voz baja al recordar este hilo. Probé el maletero, claro, la alarma empezó a sonar; por suerte, la aplicación me permitió cancelarla y también desbloquear el coche.
Me sorprendió un poco que el auto decidiera que alguien que intentaba entrar al maletero estaba intentando entrar ilegalmente y que valía la pena notificar a todos los vecinos.
Me pregunto si esto es un fallo o simplemente una limitación del sistema. Tiene que bloquear el maletero aunque se detecten las llaves cerca; de lo contrario, no se podría cerrar/bloquear el maletero estando de pie junto a él. Pero quizás habría sido una buena idea añadir un sistema para detectar las llaves dentro del maletero.
The exact same thing happened to me, I had to go home to get the spare key.
I solved the problem by updating my Luxury/Trophy vehicle to R67. Just to be safe, I performed the same process to see how it would behave, and the trunk opens by itself when I leave the key inside and try to close it.
    Votes: 1,094 77.8%
    Votes: 211 15.0%
    Votes: 103 7.3%
