Tangoed Man
Just get a small petrol generator for goodness sake.
Which option did you go for?I've splashed out on an EPS facility to add to the system.
If the power goes out, the central heating boiler will continue to operate from the home battery (and that will heat the water tank as well), and I have a double power point in the fuse box cupboard that will be live.
Oh I see - you've got a few circuits?From that I can run extension leads into the living room and kitchen to power the necessities. So now I think, how would I operate this if it ever turns out to be needed? I'm thinking maybe a four-socket extension lead from each of the live sockets.
That would probably work OK. Then at night, in a prolonged outage, the fridge and the freezer could be plugged in overnight and the'd hold their temperature reasonably well during the day. I'd just need to watch that just about everything else was turned off if I wanted to boil the kettle, or I'd trip something. The battery won't deliver much more than 3.5 kw.
Like you I did this when we were having the backup system installed.I'd also have the option of running another extension cable in from the car and using that directly - as I did this morning when the whole system was off for the installation. I was able to hand the electrician a mug of hot coffee while he was working with the electricity off.
We've got a heat pump now so that will require a lot of power.For a day or so this would be absolutely fine, but what if it was more prolonged? (A friend of mine lost power in Sussex for a fortnight after the big storm of '88.) So long as there's a working charger close enough I could go get more electricity there. There's a big motorway service station with a stack of Applegreen chargers about 22 miles away, and Edinburgh is closer than that. However, I have no way (at the moment anyway) of getting power from the car into the home battery. I have no real idea what the boiler takes in a day - it depends on how hard it's working, and of course it cycles on and off.
If it is like ours you can just switch it over whenever you feel like it.The solar will provide a top-up for the home battery during the day, but if the weather is bad I think it's possible it won't be enough. Of course I could run everything but the boiler directly from the car and just keep whatever is in the home battery for the heating, and probably over the days there would be enough solar.
I have to beware of hoping there will be a power cut just to try this out! It's just in case, for an emergency. But I do need to think about what I would do, to be prepared just in case.
Rolfe already had an expensive system that has a backup power option built in.Just get a small petrol generator for goodness sake.
Why add an extra, separate, technology?
I went for the one where you have to manually switch it over, so I'd have to go outside.
It isn't automatic, which would be more convenient but that was much more expensive to add and I'm hoping not to have to use it often, all being well.
That was the original option for the Givenergy system but they later added more options.
We've got the whole house backed up but will have to make sure to turn off all large appliances (like the car charger) before switching it over as the battery only offers 16a.
It is more convenient in some ways, but more risky I suppose because we might accidentally overload the inverter and it will shut down for 10 minutes and potentially reduce its lifespan.
Haven't used it since!
It is only 16a though I think and rarely uses more than 1kW at a time so it might be fine to run off the battery, though the battery wouldn't last long.
I'm considering raising the idea of adding an additional battery with Pebbles and the extra backup potential could be another bonus I hadn't considered.
There was one time when I switched to backup power but was stuck on the backup long after the power came back on (it wasn't off for long). This was because I didn't want to interrupt a process that had started in the meantime. Can't remember what it was, maybe a software download/update process or bread making or laundry or something.
According to an internet blog post I just read an oil burning boiler will use about 0.9kWh a day so not nothing but also not a huge amount.My only question is really, how much does the boiler take when it's running, and how likely is it that the solar would keep up? If it didn't, well, the neighbours are still there.
When we moved here we seemed to get a lot of power cuts that lasted a couple of hours or so. Fortunately we already had a wood burner but I did buy a cartridge gas burner. Good insurance as we haven't had one since, of course now I can plug the boiler into the car if needed.I guess but for a prolonged outage with little or no solar you will be hard pushed to run everything off a 13A socket.. a gas cartridge stove is a no brainer, 1970s or not.. or even a woodburner fire, now that is going back![]()
I'm sure the price has come down as these things get more common.I thought I was getting one that would have to be manually switched over and I was OK with that, but when he was showing me the finished product it turned out that the switchover will happen automatically. I hope I don't get a nasty shock when I get the bill!
I'm slightly hazy about the specifics, but basically I've got the central heating boiler being fed from the battery, and that double power point to use as I like. It should be OK, because the boiler is using kerosene to produce the actual heat, the electricity is just running the pumps and so on. If you were using electricity to produce the actual heat I imagine it would be a different equation.
On the other hand, if export tariffs are going to be slashed, will we all be adding extra battery storage to keep our solar rather than exporting it? That would make a difference!
I think ours uses around 150w when running according to the IHD.According to an internet blog post I just read an oil burning boiler will use about 0.9kWh a day so not nothing but also not a huge amount.
Especially because there is a rumour that with an extra battery and a software update the Givenergy systems like ours might be able to output at higher rates in the future.On the other hand, if export tariffs are going to be slashed, will we all be adding extra battery storage to keep our solar rather than exporting it? That would make a difference!
We have quite a few hrs per day that the coal fired power stations have to pay to put power into the grid. This is because the grid is over supplied, they can switch off the solar on rooftops, turn wind turbines out of the wind, but coal fired power stations can't just turn off the steam turbine as they need to keep them spinning to be online and generating when the peak loads hit as the sun goes down.That I had not heard about. We'll see what happens. If they make it uneconomical to export then we'll just have to pump the Aussies for advice.
I was hoping that would come to WA, but we are behind SA.We have quite a few hrs per day that the coal fired power stations have to pay to put power into the grid. This is because the grid is over supplied, they can switch off the solar on rooftops, turn wind turbines out of the wind, but coal fired power stations can't just turn off the steam turbine as they need to keep them spinning to be online and generating when the peak loads hit as the sun goes down.
The latest tech being built here in our home state, roughly 100kms away, is a device to connect the EV to the house and grid, and/or recharge from either supply.
This means, when the grid doesn't want your solar, the system charges the EV battery but also uses that battery to stabilise the energy supply if the sun has a cloud floating by and blocks production or the production drops significantly.
To add to the gains, particularly here in South Australia, they actually pay customers to take power from the grid for battery storage, but I expect that will dry up soon with some many big batteries coming on line throughout the state.
We have a lot of wind turbines and if the sun isn't shiny, you can count on the wind to be blowing, the problem is when both happen at the same time ..... so having a spare EV battery available to soak up some of that better than free electricity, can be a real bonus ......
T1 Terry
