Corroded (rear) discs
I tried this on my MG4, and it definitely DOESN't happen this way.
Keeping a steady pressure on the accelerator with right foot, and a +ve power meter, any pressure on the brake pedal with left foot, instantly turns the power meter to -ve numbers!
That's different to my MG4 where I'm pretty sure the power meter remains positive when I left foot brake while pressing the accelerator. It's how I cleaned up my discs pre MoT. I'll double check next time I'm out in it.
If you are correct, that means we can't assume any behaviour is consistent over the range.
Our poverty pack certainly cuts the throttle as soon as the brake pedal is touched, that is how I ended up with the MG running over the stops on the trailer .... learnt, albeit a tad late, use the park brake and throttle for manoeuvring ..... not sure if applying the park brake while planting the throttle would work, as I've mentioned before ..... I have my own disc cleaner ;) :ROFLMAO:
T1 Terry
T1 Terry
Pulling on the parking brake overrides the accelerator, I've tried it to answer someone else's question about it a while ago;
As far as the topic is concerned I have a long stretch of quite road (the one in the above video) where I switch to Neutral and brake hard to clean the discs every now and then. I always reverse out of my parking spot at home, so that uses the friction brakes as well, but probably not enough to clear the discs.
Hard/heavy breaking at full charge is also effective for cleaning the disks as regen is disabled at 100%
One of the issues is People have not always been able to fully clean their discs using this method due to issues with their pads applying uneven pressure and only cleaning part of the disc
That's why using the EPB lever is handy - it slams on the rear brakes thus fully applying the pads to the discs. :)
A mechanic at Hyundai told me he recommend this. I never tried it when I had my Ioniq, but it's actually really aggressive in the MG4 and from higher speeds really does stop the car quickly. I wasn't sure if cars had brake shoes in addition to the brake discs, so always presumed the EPB would use the shoes if it did (which would wear out very quickly using from high speed), hence shied away from.
I checked what happens when I left foot brake and have found out what I have been doing! The power meter does indeed go negative when I first touch the brake but then I press the accelerator further while keeping the brake pedal pressed and the power meter returns to being positive. The brakes must still be working at that stage as when I release the brake pedal the car accelerates without pushing further down on the accelerator pedal (flat road). I tried this multiple times today and that's how it behaved each time.
Thanks PeteC, that's cleared that up, I'll give it a try myself later.
I guess there's an optimum level of power and braking that does a good clean without stressing anything. I'm guessing it would be safe to keep power under 10???????
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
