Rip Van
Has anybody cleaned their rear discs manually, after being told they need replaced due to corrosion?
All seasons are a great idea, I had them on my Sportage for four years, also fitted them on the MG4 a few months back, it saves the hassle of having to swap between summer and winter.I have an update. I left Caliban at the local garage to have his winter (all-seasons) tyres put back on. I also asked them to check the brakes, also the minor undertray damage the dealer had said was dangerous and needed new undertrays. Verdict, all is fine, undertray damage (some small holes) wasn't any worse and the brakes don't need any further attention at the moment.
My dealer is a shark. Not that they're my dealer any more.
Do the winter tyres come with those screw in studs? The wife would love a set of those, she could literally tear up the road with a set of thoseAll seasons are a great idea, I had them on my Sportage for four years, also fitted them on the MG4 a few months back, it saves the hassle of having to swap between summer and winter.
T1 Terry
Norway. You can hear them rattling on city roads.No. That's snow tyres. You practically never see these around here these days. Maybe in the Alps.
Haha …. I tried that when Vauxhall used to do their track day events with their (then) range of cars VXR’s etc.Reversing into parking spots can also help to clean off the discs as there is no regen in reverse
Reverse Spinning Parallel Park | Gifrific
A car reverses quickly and then spins in between two other cars for a perfect parallel park.gifrific.com
I remember when the Vauxhall owners put on a discounted 'skid' training day, a lot of fun I actually learned a lot of things regards ABS and cadence breaking.Haha …. I tried that when Vauxhall used to do their track day events with their (then) range of cars VXR’s etc.
Brake corrosion is caused by using high levels kers as the brakes don't get any use. Keep kers to 1 and use brakes as in an ice car, saves mega money on new discs etcThe corroded brake disc replacement is a well known and lucrative wheeze by all main dealer service departments. Before they removed asbestos from brake pads and got China to make the discs out of shit steel, I use to get at least 80k miles out of a set of front discs on big ICE BMWs and Audis. My tip is to take the car up to around 50-60 mph on a straight, dry road, check your mirrors and brake hard a few times before taking the car for a service, especially for an MOT test. Better still if you can put something heavy in the boot like bags of sand.to help clean the rear discs
I do this regularly when I'm on my own, never with the Mrs in the car, she'd play hell with me.I would advise taking the car on a back road driving at 50 mph plus and applying the foot brake with heavy pressure should clean the brakes of rust , and do that every so often and you will have nice shiny brakes .![]()
The problem is that regardless of the regen setting, pressing the brake pedal increases the regen %age first before applying the physical brakes. So the regen setting is largely irrelevant.Brake corrosion is caused by using high levels kers as the brakes don't get any use. Keep kers to 1 and use brakes as in an ice car, saves mega money on new discs etc
