Dash cam battery drain with 24hr parking monitor ?
boomish
london
Not an MG
Is anyone using a dash cam that has 24hr parking monitor Successfully? I’ve bought a new Jansite 4k Mirror dashcam & hardware fitting kit, but after reading all the threads on dashcam fitting & ordered ATS fuse taps, I then started reading the fitting kit has a battery cut off voltage to not drain the battery, after that all the battery draining threads on the MG5, so now I’m paranoid that fitting a dashcam that’s going to draw current when the car is off it might not be great for the battery in the MG5.
I could just not bother connecting the continuous power part or an accessible switch in case we store the car, though you can turn this off in software, I like the idea of a switch.
Appreciate any advice.
I had this issue with my MG3, so now I plug it into the accessory socket. Dashcam powers itself off its own battery when the car is off.
In the end the Dashcam I got had the wrong orientation with the camera on the left hand side of the mirror, a bit useless for UK right hand drives I thought so returned it. Am looking into others ..
I know I don't drive a 5 so apologies, but this is the one Thinkware F200 pro I got for the ZS, it allows you to set a time for it to run after switch off, it also monitors the battery voltage. it works for me and no problems after a year of use.
My own humble ZS RHD solution, but not continuously powered:
