Dead car / flat 12 volt battery ?
Hi All
I too have a USB Lithium jump pack (This one: www.amazon.co.uk/gp/product/B09KNBSPG3). It works brilliantly on my daughters 1100 Picanto but never yet tried in on the MG5 LR.... Has anyone actually used it on the MG5 to 'Jump Start' it in the event of need.. In other words I guess I'm asking are we sure this will actually work on an EV in the event of need or does the EV actually need the voltage to be at a certain level, rather than just providing power to turn a start motor and make a spark?
Cheers all - Charles
Unless the 12 volt battery is completely flat, then when connecting the jump pack to the battery to the car, it will be ready to boot the car almost straight away.
On an ICE car, the pack needs enough power to put enough energy into the battery first, then to turn the massive drain of the starter motor, then the ICE.
A jumper pack will therefore have plenty of capacity to start a much larger number of EV’s then ICE cars.
Once the battery has hit above 12 volts, it will pretty much provide enough energy to boot up the EV.
Hi All
Hi Charles- I’ve not used my jump starter on the 5 LR since I bought it. The car was totally dead and wouldn’t even open the doors. I called the MG Assist - AA and the guy jump started it with his unit in seconds. That was when I bought my unit.
As there’s only a bit of switching to do on the EV it’s so much easier to start them than churn over against the compression and gears and oil in a dinosaur powered machine. I think you’d get loads of EV’s started as opposed to two or three engine starts.
Have fun - oh and keep the jump starter handy at the front of the car near the driver’s door so it’s easy to reach it.
Aye, I’ve drilled and filed the 10 mm spanner to save weight but still working on the shovel ??
The scary twilight charger ( A cautionary tale )
A driver with an unlit car
When all around was gloom
The senses were too sharp by far
Foreboding thoughts of doom
In a state of agitation
In this lonely highland Glen
This guy caused consternation
By shouting “give’s your ten”
Well I had to have some power
From this only plug for miles
So I asked at that late hour
If two fives would make him smile
At that he went quite funny
In a jovial sort of manner
“I’ve no interest in your money
Just lend’s your ten mil spanner !”
Very nice personal pressy and I sincerely hope you never need it ?
My unit rests under the driver’s seat. I did have it in a side pocket in the boot but that’s the least handy place I reckon. When my 12 volt battery was too low powered to even open the doors I had to flick off the chrome cap on the door handle. This revealed the keyhole for the “flicknife” key blade to unlock the door.
Then I would have had to reveal exactly how unfit I’ve become. Climbing over the seats and faffing about opening the luggage cover would have produced a comedy show of epic nonsenseness.
Additionally, I’ve now had my unit for a couple of months or so. I plugged it in before our three day trip recently, and found that it took half an hour or so to top it up fully. So I’ll now try to plug it in two or three times a year (calendar suitably marked up).
It seems these units can crank up even a diesel a few times and, as you say, EV’s only need a relatively tiny bit of power to get thinks going.
And the Panda should be fine ?
Yeah - OK I have had this jump starter unit under the passenger seat since buying it and forgot all about it until today.
So folks - TIMELY REMINDER -
Check that if you carry one of these units - check it’s fully charged and ready for winter - you never know ?.
This one was only ten minutes away from fully topped up ??
These are back in middle of Lidl
Personally I’d go for it, but I bought a NoCo booster HD - bigger and more expensive but does the job.
The good thing about this is the battery chemistry - LiFePO4 pretty good for the price.
