Difference between Eco, normal and sport modes
MartinSEsr
wolverhampton uk
Hi, I haven't seen this anywhere, so asking here.
There are eco, normal and sport modes - what are the differences? Is it just the feel of the car? I know sport steering is heavier than eco, but is the rest of it just down to a different throttle response, ie sport is harsher for the same throttle input? Or does sport mode actually have more power and acceleration?
If you drove all the modes in the same way, ie moderate acceleration, same cruising speed, same regen braking, would eco actually be any more economical (assuming the AC isn't set to go to eco mode at the same time) ? I haven't read anything to indicate why eco would be more economical.
Thanks
Sport mode gives you instant throttle response, Normal softens the power delivery a bit, and Eco softens it more so. That's the main noticeable difference.
Eco is more efficient simply because you accelerate less quickly for the same throttle input, as the power delivery is lower so less battery power is used.
Hi, there are threads on here with throttle response graphs.
You need to just try different modes until you find one that suits your driving style.
Why the hell anyone bothers with ECO mode in any EV baffles me.
Completely nullifies what’s best about EVs.
Like buying a nice stereo and hanging washing over the speakers.
Mentalist behaviour.
I've got a trip to Madrid planed as soon as ours is delivered and as it's motorway all the way I'll probably use ECO mode for a lot of it to try and eek out as much range and minimise charging stops
Not sure ECO makes a blind bit of difference when cruising.
Eco mode does reduce the effectiveness of the heater so might increase range at the expense of comfort. However, if you want to do that you can just turn off, or turn down, the temperature of the heater instead.
If you want more range then it's simple. Coast as much as possible, avoid regen and braking at all costs and keep your speed below 60mph whilst not using the heater. It's more about how you drive rather than the mode you are using.
I prefer sport mode but I'm to lazy to change it so usually stick with normal.
Remember also to put the regen into low or adaptive on the motorways.
I suspect many people don't realise that all it does is make the throtte response dull and spongy, and they assume it makes the motors or something else more economical.
Certainly cruising at 70 on the motorway with ACC on, there would be zero difference in battery consumption.
But it won't make any difference - cruising at a steady speed, eco and sport would use exactly the same amount of power. It's just the throttle response that changes.
I’ve attained that age
Where eco’s fine
And melodic washing
Is just sublime
So I’ll bumble along
With my five a bit late
Not dismounting the car
With a John Wayne gait. ??
I prefer eco mode otherwise I go shooting across at dangerous speeds.
I do .. Because I like the setup.. - Doesn't mean I don't enjoy the driving experience (safely)
The responsiveness of the accelerator pedal at low speed is something I wish was better. In sport mode it's ok but I don't think it's as good as the leaf was, normal mode is not even close. The pedal just feels a bit mushy.
    Votes: 1,089 77.8%
    Votes: 209 14.9%
    Votes: 103 7.4%
