Anon70
- Sep 24, 2023
- Scotland
- MG4 (2022-2025)
It depends how many miles will be driven with the ACC on.
ECO will mean you have to push the go pedal harder to use more battery, if you will be accelerating gently in normal mode you will achieve the same thing.
As mentioned above in the XPower eco prevents the front motor engaging, but this can be achieved in normal mode with gentle acceleration.
The other time eco will save you battery is if you have the heater set to reduce power use when it eco is active. Another way to achieve this is just to turn off the HVAC all together.
With the ambient temperature above 15 deg C it will be driving style as much as mode that gives better efficiency.
