difference between SOC and SoC
decrep
Solutions
Mandurah Western Australia
I've just acquired and OBD scanner, and playing with it to see what it does. It has %s for SOC and SoC, one the same as the car display, and the other a bit higher. Google doesn't seem to know about this, it only has info on SOC1 and SOC2.
I think I saw it mentioned on one of these forums, but I can no longer find it.
So any clues, anybody?
Yeah but now carscanner has CarPlay integration it’s not great to have to reconnect the dongle every time.
I couldn't get carscanner to connect to CarPlay, it seems stuck on google maps or music.
Also how do you get the graphs onto the computer. I can't find anything that will open the .brc files. Or take a screenshot of the app display.
I don't see any export facility at all, do you need the paid version for that.
Apparently the .brc format, is from a Bryce 3D modeling app, used by different sorts of programs. Some of these other programs may be able to open the file, but whether they than can make sense of it is another matter.
I'm not sure I want the data as a spread sheet, I'd like to see the graphs on this computer.
It would be fine if it had a laptop program. but it only does phones.
I might be wrong on this one but you can run Android apps on Windows natively now.
Plus a spreadsheet is easily converted into a chart and Copilot can do that for you really easily
I do have the premium version of car scanner I think it’s worth every penny
Yep, the app has it labeled, if you look in the right place. SOC is the real battery state, SoC is the displayed usable charge.
Is the displayed value on carscanner the same as shown on the drivers screen?
If it is correct that is only for the SE. On an LR the displayed value is several percent out presumably because the buffer at each end of the battery is different.
That's interesting thanks. Given enough raw SOC values and the corresponding values from the car dash I can create a custom value for the LR SoC.
Do you have any delays in the carscanner dashboards loading? Mine take up to 10 seconds to complete and some values are blank or nonsense.
yes, can't remember exactly what it said about the MG4 profile, something like beta, or maybe provisional? So I guess it's still a work in progress.
I also have blank and meaningless values.
The android auto screen also lacks the nice graphs.
So you want, a range of charge states, with SOC and SoC values?
Hmm just checked and it's not what I thought.
Car says battery at 72%
Scanner says SoC displayed 74.19.
State of charge 73%
That doesn't add up?
Also I'm not sure if our different battery chemistries make this relevant to you?
Could it be the reason the LR version doesn't have the 2 values?
State of charge 73%
My wild guess: the car truncates down (say 72.6 → 72), and the app rounds up (72.6 → 73). In my limited experience, Chinese software and firmware rarely bothers to round numbers properly, even though it's quite easy.
Edit: Oops, I see your point; the "SoC displayed" should be the one that agrees with the car, and should be the higher of the two, at least at higher SoC and SOC.
So that doesn't work out; sorry.
    Votes: 1,081 77.7%
    Votes: 208 15.0%
    Votes: 103 7.4%
