Equalisation charge - NMC battery
MarkHoward
Age
75
New Zealand
Two questions please:
1. Has it been clarified yet whether a full equalisation charge is achieved with an NMC battery at 80%? (or will that only happen at 100%?)
2. Is it possible to achieve a full equalisation charge (at either 80% or 100%) using scheduled charging - or will the charge terminate as soon as the charge gets to the specified charge level, without maintaining the charge connection so as to achieve the balancing? (Reason for this is to balance during off-peak power - in the middle of the night when I'm not able to watch the charge rate)
My 2022MY Trophy (64kW NMC) will balance the individual cells when it reaches the specified %age. This is evident from the gradually reducing/fluctuating current draw one the desired %age has been reached, down as low as 80w. The range and social do not change during this process and eventually the car will terminate the charge, if I use the Zappi it reports EV Full, even if I've only requested 80%. I don't use the cars schedule charging unless I am using the 3 pin evse, If I use the Zappi I'm either on eco+ to just keep adding solar until the car terminates the charge or using Octopus smart charge I ask for nn% to be added certain time, in which I usually ask for 10% more than there's space for to ensure a balance charge.
Unfortunately this is a topic riven with false statements and often dogmatic positions.
@MarkHoward, you have introduced the adjective 'full' in front of 'equalisation' and this can lead to some saying that a 'full equalisation' can only be done at 100% battery level.
The MG4 manual shows the information, from different parts, as below.
From the first extract it could seem that an equalisation charge means charging to 100%. However the emphasis of the extract, to me, is the achievement of the 'optimal equilibrium state' through slow charging with an equalisation phase.
The second abstract provides a definition of equalisation charging, that it is charging continuing after a 'normal' charging process has completed. It does not define a 'normal charging process'. For MG4s with an LFP battery this must be 100% since there is no charge level adjustment. However, those MG4s with NMC batteries can alter the charge level and 80% is consider the 'Health' level. So it can be considered that equalisation charging can occur after normal (80%) charging has occurred. By analogy other set levels can be substituted. But not going to 100% does not create an 'optimal equilibrium state'.
I have not seen a post by anyone stating they have seen the 'Please Slow-charge the Vehicle's message.
The third extract requires you to do a regular slow equalisation charge.
To continue the above, I believe my MG4 Trophy with its NMC battery equalises the battery cells after completing its charge to the set level.
Whilst it is doing the equalisation the info screen shows that it is doing 'Balancing', which can be considered the same activity. See image below (not mine):
Thanks for your thorough responses.
So, the MG4 manual is not crystal clear about exactly what is required. Seems this has been caused by them trying to keep the manual (too) simple when covering both LFP and NMC batteries.
I think the only way for me to be sure is to sit in the car and watch what happens to the charge rate at the end of a charge to 80%, when I'm doing a scheduled charge. (just using a granny charger)
The car is getting its 1 year service today and I've asked if they can tell me how well balanced the cells are. Not sure if their software will tell them this. How many cells are there, BTW?
The 51 and 64 kWh models each have 104 cells in series. Difference is 51 is LFP and 64 is NMC.
In my 64 at the end of a charge to 80% the charge rate drops down and fluctuates between ~50-100 W indicating a period of balancing. Usually takes about 5 minutes give or take. If it's been a long time though since the last balance and/or with several DC fast charge sessions then it can take an hour or so.
It will do the same at pretty much any max SOC charge setting.
LFP however should only balance when at full charge. It's to do with the voltage - SOC relationship, it is quite different between the two chemistries meaning balancing logic needs to be different.
So (for the avoidance of doubt) even using scheduled charging, with an NMC battery, the balancing will occur after the charge reaches 80% and before the car disconnects the scheduled charging session? That would settle my mind greatly, if that is the case.
Another way to see the car balancing the cells is when the app states you’ve reached your set % (so 60%, 70%, and 90% should also balance) but hasn’t stopped charging yet. The finish time will keep updating to the current time.
You could sit in the car and wait for the balance screen, but I would just trust that the car balances.
Scheduled charging implies a time limit.
If the scheduled charge ends before the car reaches its max SOC setting then no, it won't have performed a balance (equalisation).
If the car reaches the max SOC target before the end of the schedule, then it will commence balance (equalisation) charging.
Whether it gets to complete that equalisation process depends on whether or not the time remaining in the charge schedule is long enough. It may only need a few minutes, however it might need a couple of hours. It depends on how out of balance the pack is.
Mine balanced at 70% a couple of months ago as I charged it during a period of free electricity I had, during the day, from EDF. I didn't want to go over the free time or change the Pod point schedule so I set it to manual and 70% in the car, I knew it would reach 70% before the end of the time.
FWIW I get about 10% per hour on my charger, so it's easy to work out roughly when it will reach the required SOC.
    Votes: 1,009 77.9%
    Votes: 191 14.7%
    Votes: 96 7.4%
