Minor CCU connection problem
Our guests have just left after having charged to 100% last evening, This was at the 10kW rate with sporadic cut-offs and resets but eventually getting there, air temp 20°C, EVSE getting up above 59°C.
This morning I wanted to put in around 40 kWh. Started at the 10kW rate but it shut down and restarted a few times before putting in 19 kWh. (air temp 17°C, start temp 30°C, stopped at 58°C). I then stopped it and changed the car screen setting to 8 amp and restarted. On 3 phase this gave a total input of 2kWh. Changed the setting to 16 amp and again restarted and got a total of 3.74 kW or 1,24 kW per phase or around 1/3 max value. The charge has continued unabated and the temp has dropped to 52°C.
Prognosis: at least I think the car is fine and not causing the charge cut-offs.
In all the above cases the EVSE was getting warm but not ( by touch ) to reported values.
So either the thermistor is faulty and sending values to the microchip which are wrong or the microchip is faulty and not interpretating those values correctly.
Or everything is correct and a fault in the contactors is actually making them too hot, and its shutting down as it should.
I have been looking at replacement units as a straight swap, but I want to throw out an idea to the forum. What if...... instead of getting a 11kW box I got a 22kW version , but keep the same RCD, wiring etc. The car would still only draw 10.2 kW but instead of running at its maximum capacity the EVSE would only be at half its potential capacity and should as a result be less temperamental. Well , that's the theory, If any one can see a fault in this I am all ears. I could uprate all the RCDs , breakers, and change to 6mm² cables, but for the moment that is impractical.
What if...... instead of getting a 11kw box I got a 22kw version , but keep the same RCD, wiring etc. The car would still only draw 10.2 kw but instead of running at its maximum capacity the Evse would only be at half its potential capacity and should as a result be less temperamental. Well , that's the theory, If any one can see a fault in this I am all ears. I could uprate all the RCDs , breakers , change to 6mm cables , but for the moment that is impractical
My 2p worth... generally I'm all for running electronic equipment at less than maximum rated values as a 'mechanical sympathy' gesture towards longevity. But, I wouldn't classify an EVSE as something that is working any harder at 22kW compared than 11kW - specifically for the reason that the 'power' is switched via a contactor, rather than (say) a solar inverter which is passing large currents through semiconductors (be they IGBT's / Mosfets etc.).
Sure, the wires and rating of the contactor may be meatier in a 22kW EVSE than an 11kW EVSE, but if the 11kW EVSE is getting hot that's a fault with the design of the EVSE IMHO.
Guess it will come down to the differential in cost and likelihood of you (or a guest) having a vehicle that can charge at 22kW as to whether the 'upgrade' is worth a punt.
Alternatively (and for less cost), what about a portable super-granny charger I mentioned in that other thread that could handle 7kW (single phase) via a commando socket?
The 7kW super granny is on my ,list of things to do, when I sort out the bit of a disaster we call the third house.
I agree something has gone "pop" in the 11kW EVSE, whether or not its getting as hot as it reports is doubtful. Warm, yes, 60°C hot, no. So its how its detected and interpreted that's the issue , the false interpretation triggering the cut-off. Bad design , poor quality PCB . failed solder , bridged chip. Who knows? I can still use it overnight at the lower rate so there is no rush , and it is an easy job to replace like for like , but it is cutting into the savings from buying diesel if you need to replace the EVSE every two years.
If the larger capacity EVSE is designed to run at 22kW and I'm only taking 11 kW then the internal heat produced should be less , and hopefully a longer longevity. I am just trying to find out all the pros and cons of such a move even though I don't intend to pull 22kW ( or even try ) at all in the future. So its not really future proofing as we commonly know it.
If the larger capacity Evse is designed to run at 22kw and I'm only taking 11 kw then the internal heat produced should be less
Guess depends where the heat is coming from. Is the existing EVSE still under warranty? If not and you are up to taking it apart then it's likely repairable (assuming one's knowledge of electronics goes beyond knowing the difference between a thyristor and thermistor, that is ;) ).
Do you have, or know someone who has, a FLIR camera? - that would be the safest method to identify the hotspot - if indeed there is one. If not, my tried-and-tested method would be to run it with case open (keeping the cats at bay), then turn off all power and quickly use one of the 10 digital thermometers you have (5 on each hand) to feel for the heat source.
If it's not as hot as it thinks it is, then pop over to Tandy to buy a new thermistor or add a series resistor, as @Coulomb suggested, as a workaround.
Yes, no need to shell out for a 22 kW EVSE. That will be an expensive monster, and you have have trouble getting an electrician to install it on an 11 kW circuit. In the future, someone might plug in a 22 kW vehicle. I guess all that will happen is that the breaker will trip, but that's not good for the on-board charger in the car.
As Everest says above, get it fixed or replaced under warranty, or get it repaired, repairing it yourself if you're up to it.
I believe that the latest Zappis are 7kW/22kW single/multiphase capable. So you can install on any supply but they are built to take a lot of load.
Of course, Zappis are expensive but they also seem generally reliable. Mine hasn't missed a beat in nearly 3 years.
I have a good knowledge of taking things apart, then it seems to go pear shaped !!!!! I think this is beyond my paygrade. Its out of warranty but Morec do seem genuinely interested in the prognosis , but I think the postage to return it for repair plus the costs might make it a consumable item, which goes against the grain. Pun time, I'm warming to the idea of a thermistor but there's no need to take the thys. Couldn't resist . Double pun? :D
I could try searching for a local electronic person/enterprise so they could give it the once over, ever seen a Frenchman sucking in fresh air and tutting at the same time. :whistle:, normally before the lightening of my wallet.
No but I've seen them giving the Gallic shrug when you query the price 😁
You could contact Morec and see how interested they are and would they pay for the postage but if it was me I would cut my losses and replace it with a different make. Yes I know it goes against the grain to throw away a possibly repairable item but when they are less than a third of the price of a Zappi it makes you question the build quality.
In general I'd agree , but we all bought MGs not Audi, Jags, or BMWs so I would continue with the nervous twitch gamble of a cheap and cheerful and replaceable option. And I think I've seen posts about errant workings of the more expensive EVSEs as well. Not that the forums for the above mentioned vehicles are all sweetness and light either. "You pay for what you get" seems to be becoming a less accurate saying than the view traditionally held.
On re-reading your first post, the trouble seems to have started after guests used your "charger". Maybe the combination of their car and your EVSE somehow damaged the EVSE. The only damage I can think of is arcing of the contactor contacts. Unfortunately the contactor is probably the most expensive part of an EVSE, unless you count the main board as a single, unrepairable item (I don't, but I'm an electronics engineer). Damaged contacts would get hot, so that would explain the high temperature reading. Though you'd think that you would be able to feel 60°C type heat through the presumably plastic case
If the contactor contacts have been damaged then reluctantly I'd have to agree that it's not repairable, unless you get very lucky.
I'd still suggest opening it up for inspection. Perhaps post some photos of the contactor (or relay, some use a relay in place of a contactor). That assumes that you are confident in your ability to open it safely.
If it turns out instead to be an electronics issue, then it does seem a shame to replace a presumably multi hundred pound EVSE for the sake of a part costing less than a pound (ignoring delivery).
At any point was the power to the "charger" cut off by turning off the breaker in the distribution board? (Forgive me if I mistranslated into British, we call them switchboards down under.) Then the breaker and contactor would share the punishing kick back from the car's inductor. Charging should always be terminated electronically, when possible.
Possible, but it started around 4 weeks ago , with only putting around 30 kWh in. It's still usable but needs monitoring so it makes over night charging a hit and miss affair. It's still absolutely fine if I drop the car's request down to 16amp from Max.
Hello
I have a question about the CCU. I had a collision (actually, I hit a rock while reversing). I damaged the CCU (the housing cracked). I bought the CCU from a wrecked car. The model numbers match: EP3CCU1130B...but... after installing the new CCU, the car won't charge (everything works fine on my old one with the cracked housing...but I want to replace it because sooner or later water will get into it). I get the P1FC0 error. I connected to the MG server via VINCI, but I can't access the programming tab there; that tab is inactive. My question is: does anyone know how to add the CCU to the vehicle? Do I have to add it? Or can someone do it remotely? Thank you.
@r2d2... you'll probably get a better response by creating your own, dedicated, thread with a suitable title rather than tacking on to an un-related thread. There was someone on this forum, possibly also in Poland, IIRC, who rebuilt a crashed MG4 and might have some useful input.
As you have all suspected it has gone all quiet on the Eastern front with regards customer service.
Put a 38% charge in yesterday and by the time 12 kwh had gone in it had clicked off , the temp at 57.8°C which seems to be proper cut off temp.
Reduced the current to 16A AC but then that cut off again after another 3kWh had gone in. I let it cool down for an hour and tried again , the car reverted back to max power and the charge finished with a balance with the temp at a bum squeaky 57.6°C.
I cut the power to the unit and unhooked from the wall plate, to find that the steel mounting plate screwed to the unit was quite warm. Its not very large and the way it's mounted means there is only a restricted airflow when in position. I removed this to see if there were carcass screws underneath. Niet, its a totally glued/ bonded construction and so pretty much inaccessible.
Enter Heath Robinson, I made up an aluminium plate with twice the surface area than the steel one with its sides extending out into the breeze . I sandwiched this between the EVSE and its mounting plate in the hope the extra area and heat conductivity will leach away the unwanted excess heat.
This is now back on the wall awaiting its next trial. As an extra cooling measure a few hours before the next charge I will put a steel block in the freezer , then at the last minute rest it on top of the EVSE before the charge starts to see if that has a positive cooling effect. Until then!
Put a 38% charge in yesterday and by the time 12kw had gone in it had clicked off , the temp at 57.8c which seems to be proper cut off temp.
Reduced the power to 16a but then that cut off again after another 3kw had gone in. let it cool down for an hour and tried again , the car reverted back to max power and the charge finished with a balance with the temp at a bum squeaky 57.6c.
I cut the power to the unit and unhooked from the wall plate, to find that the steel mounting plate screwed to the unit was quite warm. Its not very large and the way its mounted means there is only a restricted airflow when in position. I removed this to see if there were carcass screws underneath, Niet, its a totally glued/ bonded construction and so pretty much inaccessible.
Would an external fan help on the heat plate?
It's always an option worth exploring , I would have to set it on a timer to coincide with the charge times.
Doing some fag packet calculations it does seem to go up 1°C every 2 and a half minuets , which means something is amiss. My latest ever changing theory is that the contactor is overheating for some unknown but guessable reason. The time between cut outs is getting less so its getting worse . At some stage I might admit defeat and renew it , I can then butcher it just for a look see . :oops:🪓
Its always an option worth exploring , I would have to set it on a timer to coincide with the charge times.
Doing some fag packet calculations it does seem to go up 1c every 2 and a half minuets , which means something is amiss. My latest ever changing theory is that the contactor is overheating for some unknown but guessable reason , the time between cut outs is getting less so its getting worse . At some stage I might admit defeat and renew it , I can then butcher it just for a look see . :oops:🪓
Yes, it sounds likely. Some cheaply made EVSEs use low quality components that are not really up to the job for the long term. Could be the case here.
After a while Morec have got back to say that the box is not a repairable item , and that they agree there is a fault , but due to overuse????? if 50 charges in 2 years is overuse. ( 2000 kwWh ) .
They did however gave me a code for Amazon to get a 30% reduction on a replacement EVSE. So not overly disappointed. ( as the present one is still usable).
Now if only something would go wrong with the MG , an additional 30% off a MGS5 might come in handy now I've got a Chinese company to set a precedent! :cool:
After a while Morec have got back to say that the box is not a repairable item , and that they agree there is a fault , but due to overuse????? if 50 charges in 2 years is overuse. ( 2000 kw ) .
Now if only something would go wrong with the MG , an additional 30% off a MGS5 might come in handy now I,ve got a Chinese company to set a precedent! :cool:
Wow! And you thought the EVSE was purely ornamental!! 😂
I tried the "fault due to overuse" argument on a past boss of mine once and needless to say my workload only increased....!
Spoke too soon,,,,,,, Morec sent me a link to Amazon for the replacement box ( 299 euros ) and said they would provide a code for a 30% reduction. Not yet received .
On Morec,s own site the same box is , wait for it 199 euros. I have no doubt the code is only valid for Amazon? Hang on , there's someone at the door........ its OK its only a Trojan horse . :rolleyes:
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
