- Jan 31, 2023
- Location
- France SE,LR23
- MG4
Our guests have just left after having charged to 100% last evening, This was at the 10kW rate with sporadic cut-offs and resets but eventually getting there, air temp 20°C, EVSE getting up above 59°C.
This morning I wanted to put in around 40 kWh. Started at the 10kW rate but it shut down and restarted a few times before putting in 19 kWh. (air temp 17°C, start temp 30°C, stopped at 58°C). I then stopped it and changed the car screen setting to 8 amp and restarted. On 3 phase this gave a total input of 2kWh. Changed the setting to 16 amp and again restarted and got a total of 3.74 kW or 1,24 kW per phase or around 1/3 max value. The charge has continued unabated and the temp has dropped to 52°C.
Prognosis: at least I think the car is fine and not causing the charge cut-offs.
In all the above cases the EVSE was getting warm but not ( by touch ) to reported values.
So either the thermistor is faulty and sending values to the microchip which are wrong or the microchip is faulty and not interpretating those values correctly.
Or everything is correct and a fault in the contactors is actually making them too hot, and its shutting down as it should.
I have been looking at replacement units as a straight swap, but I want to throw out an idea to the forum. What if...... instead of getting a 11kW box I got a 22kW version , but keep the same RCD, wiring etc. The car would still only draw 10.2 kW but instead of running at its maximum capacity the EVSE would only be at half its potential capacity and should as a result be less temperamental. Well , that's the theory, If any one can see a fault in this I am all ears. I could uprate all the RCDs , breakers, and change to 6mm² cables, but for the moment that is impractical.
