Faulty USB-C ports?
On paper the USB-C port is able to deliver more wattage than the older types, but nowadays, most every manufacturer have their own proprietary "fast charger" protocol, and if the charger does not respond then the device will assume that the charger is a "slow charger" and only draw a fraction of what the port is actually able to deliver.
This is actually a good thing, we dont want someone to buy a cheap USB cable on alibaba, with not a lot of copper in it, and then the device tries to suck 60 Watts, making the cable light up like a lightbulb.
Oneplus for example, have their own proprietary protocol called warp charging, the charger will have to be able to do a handshake to prove it is able to do the wattage then phone or tablet wants, and it also needs a cable with a chip inside, that essentially says "Yeah, i am a capable cable, bring it on".
Qualcomm has their own protocol, apple has theirs, Samsung has a different one and so on.
Some of the "cheaper" brands use the Qualcomm one so any QC2/3 charger will be a fast charger for those phones.
It would be nice if every brand and make would use the same protocol, like EV's do now, where a CCS charger can charge any CCS capable car, and both the charger and the car, can say "I can handle this and that much" and they just charge at the fastest speed both car and charger can agree on.
That "universal standard for phone charging" exists in 2 forms, USB PD (supported by the majority of android and apple phones) and PPS (supported by some android phones). My phone and laptop can fast charge of the same USB C charger, laptop at 100W and samsung phone at 45W. It's a shame that MG didn't implement USB PD as I know other car manufacturers' are.
@ajcooper did the dealer manage to resolve the issue? I am having the same problem and wondered if it was something simple like a fuse.
Just tested the USB-C in our hired MK2 ZS SE LR and no joy charging an iPad Air 4 front or back using the Apple cable :(
Edit: I note that the USB-A can charge our iPad Pro no problem
same issue with my freshly delivered zs ev luxury...my google pixel is not charging on any of the USB port while the redmi note 11 of my wife is charging. My pixel detect a "wrong multimedia device"...
I will do additional test with other phones I have around.
My google pixel 6 is charging perfectly on USB C adapters with the same cable. I suspect it has something to do with the way the plugs are wired...
@ericgrand I don't think it is a phone issue in your case. My wife has a pixel 6 I have a 6a and my daughter has a 4a which all work fine on the USB-A ports.
I really think for charging just get a charger that goes in the 12v socket it will always be faster loads to choose from some with like 6 ports
I have the same problem, USB C in the back will charge My Galaxy A03s phone, but not my Galaxy Tab A8.
It's a pain as we have a meds fridge plugged into the USB A at the back
I don't know if an issue I reported in another thread is relevant. Just in case, here goes.
I bought cheap mini-flash drives for mp3 tracks as bigger flash drives stick out too much. I found that the system could read these mini-drives and play music from them the first time they were plugged in. But once the power had been switched off, the system could not detect the mini-drives until I had unplugged them and plugged back in. However, when I bought more expensive mini-drives, the problem ceased.
I have exactly the same problem. No charging or apple car on USB-C port. USB-A port works without any problem.
We've just picked up our new MG ZS EV Trophy long range today, and pretty happy so far. Aside from the common issue of not being able to register the app, we seem to have an issue with our USB-C ports. Both the front and back ports are failing to provide power or connect to the phone. The USB-A ports work fine. I've tried multiple cables and a couple of phones. The cables were official cables, not dodgy knockoffs.
Waiting to hear from the dealer but wondered if anyone else had encounter similar issues.
Yes I picked my MG Trophy EV up last week and it’s exactly the same, both front and back, have you heard anything from the dealership?
try couple of different cables first and if not working, take it to MG garage to be fixed under warranty.
Sorry this is a bit vague, ancient failing memory.
But I couldn't get a phone connection through the front C port, but it will play my music stick. In the MG4 the rear ports are only charge points.
So all C points should give you a charge, if they don't there's something wrong.
If you read the manual you can only plug your phone into the USB A port to use AA or Carplay.
At least this is the case with my MG ZS EV.:unsure:
It’s not my phone I’m plugging in to charge I’ve got the charging pad for that it’s the C ports to charge my Apple Watch that aren’t working
Have you tried charging your phone or another device and another cable to see which one of the car-cable-watch points is not working? If nothing works, MG under warranty ...
Both USB-C ports (front and back) on my ZS EV Trophy will not charge my iPhone or iPad Air 4th gen (with USB-C port) using any USB-C to USB-C cable I've tried (iPhone original, OnePlus Original cable, and a third party cable). Also will not charge my Apple Watch using the original USB-C apple watch charging cable.
I can charge my son's older iPad using a USB-C to lightning cable - that works on the front and back ports.
All phones/ipads charge fine using USB-A to USB-C cables and USB-A to lightning cable. Haven't got a USB-A to apple watch cable, so haven't tried that but I'm sure that would work too.
You can get pretty inexpensive USB testers on sites like temu you just plug into a port and it will tell you if there is power to the port and even what charging standards the port supports.
I just tested on mine and i get 10Watts at 5V with my Oneplus 13 on those ports.
Thats 2 AMPS which is not great but "OK" especially considering Oneplus has a proprietary protocol for their phone/charger communication so i would never be able to get "great" charge speeds.
What this equates to is, my phone would need about 3 hours to go from empty to full.
Checked the fuse layout and it seems the USB ports do not share the same fuse, and also, if the USB-A socket in the back and front work its probably not fuse related as the USB-A and USB-C sockets are surely powered through the same fuse.
What happens if you try to power any non-apple product, does it still not work.
If it does i would suggest that the
