MG Mile eater
- Jun 4, 2025
- Bridgnorth
- MG5
Hi Guys I'm new on here but not shy
As I have had a lot of experience with driving and EV , charging EV faults and expensive electricity ( CCS )
I've seen it all . Since I have owned an EV the infrastructure has got much better and charging
More reliable. Not once in 150k have I ever had range anxiety close to running out !!! Often arrive at destinations with 2-4% left
I always charge up to 100% at home every night ( if home long enough ! ) sometimes I topped on rapids to make up the full charge after on off peak.
My charging is 45% home charge 40% CCS and 15% company 7kw type 2.
Many a time I have had charge cables locked in port ( manual release)
Battey fault ( disconnect 12volt battery for short periods)
But the Main problem and still can be a problem is contactless payments
I have 15 apps on phone aswell lol !
Contactless -- if your a high user of public charging you need minimal 2 cards
Most Ezv chargers are contactless as of 11/24 all public charging must offer contactless for simple charging. I have had it where both cards won't work
Poor mobile signal or low battery
Yes there are many other ways to pay.
I use zapmaps alot and tend to go for the 150Kw ccs points an normally there at more then 2 to 4 so no hanging around
So come on you shy EV owners whats been your problems in your EV ownership!!???
