HELP with keyless start MG4, emergency please
HRL
Winchester
MG4
Have lost car key, am in car using app to unlock and when I press keyless start on app it says successful ....but not going anywhere. Know have to press brake but on youtube video says then to press start/stop button, but we dont have one do we ?? Sorry panicking now ...pleaee help me !
Its an MG4 Trophy BTW, 2023.
When I press brake it says smart key not detected, and nothing happens when I turn the dial to D.
When I press keyless start in app it says successful, but then apparently I need another start button ?
Have you tried getting out, locking it, opening it then trying again? If I recall correctly you have to do the keyless start within a certain amount of time… although I may have imagined that!
Thanks for all the replies....no idea why it won't work....currently being rescued by my son with the spare key so that better work so I can get home ....I will ring MG tomorrow and try and find out why and will post solution on here as may be useful for others in future.
I don't drive but I have set up my phone with the app so I can unlock and lock the car with it.
Also, I have set up the key. In doing this, I had to hold it up against the boss of the steering wheel.
Once it was all set up, it worked fine. I can tap keyless start, then lean on the driver seat squab and everything fires up. I can turn the selector to drive and it asks for the brake to be depressed ("You're a rubbish brake, you're no good at all, you've never been good at anything your whole life!"), so I assume the car is ready to drive on the e-key.
Wow, thank you, my app is set up and links to car but not done anything with the key so I'll try that tomorrow.
Sadly it took a couple of years for me to be able to use the Bluetooth key. I think all the planets have to be perfectly aligned for it to work ie car software, iSmart version and phone version.
I would never rely on it for day to day use
    Votes: 1,022 77.9%
    Votes: 194 14.8%
    Votes: 96 7.3%
