Agrajag
- Sep 12, 2023
- Location
- Sydney, Australia
- MG4 SE SR
I'm having a problem with my MG4 51 excite (Australian) where it sometimes refuses to start. I unlock, get in, dashboard lights up with what seems to be every possible warning. It doesn't display a battery SoC (just
The first couple times this happened I called roadside assist and each time, by the time they arrived, I'd go back to the car with them, unlock it, and it would start no problem, which was very frustrating! By this time I had booked it in to get looked at but that was a couple of weeks away. The next time it happened I left the car as-is - warnings on dash, no battery %, didn't lock it - and again, by the time they arrived, there was a battery % showing and the car started no problem! He tested the 12v battery and said it was fine. Luckily I had taken photos/videos so could show them what was happening and that I wasn't making it up!
The car went in for a service and they updated the software. Notes are:
That was just over a week ago, and it happened again today . This time we just left it and after about 20-30 minutes it started working again. I've booked it in again to get looked at. It's super frustrating as it's made the kids late for school and we just can't rely on it. My wife has understandably lost all confidence in it and just doesn't want to drive it anywhere (she was stuck far from home today with 2 kids in the car just waiting for it to start working again!)
Has anyone else had this happen and had a resolution? Or can anyone guess as to what the problem might be? We haven't been able to figure out what it is that makes this happen, it seems quite random. At first we thought it might be something like forgetting to lock it, but it's happened a couple of times when we are 100% sure it was locked.
). I cannot put it in drive or reverse, but neutral/P works. I also cannot turn it off via the Security screen, it says "Function only available in P gear" even though it is in P gear. If I get out/lock and repeat, it just gives all the same errors. When I unlock the car I don't hear the clicking/knocking noises that you normally hear.The first couple times this happened I called roadside assist and each time, by the time they arrived, I'd go back to the car with them, unlock it, and it would start no problem, which was very frustrating! By this time I had booked it in to get looked at but that was a couple of weeks away. The next time it happened I left the car as-is - warnings on dash, no battery %, didn't lock it - and again, by the time they arrived, there was a battery % showing and the car started no problem! He tested the 12v battery and said it was fine. Luckily I had taken photos/videos so could show them what was happening and that I wasn't making it up!
Read DTC found fault in every controle module - delete fault memory - checked battery condition good. Performed software update and configuration in BMS - update all modules as per TAC
