TetchyTechie
- Jul 26, 2024
- Ánslo, Norway
- MG5
There's an informative thread over in the MG4 section about Balance Charging:
www.mgevs.com
My question, born of ignorance, is whether there are any 'Best Practice' documented procedures for keeping the HV battery in good shape?
In my previous EV, I only ever charged to 100% by accident - I charged to a State of Charge (SoC) of 60% for daily driving, with the battery going down to about 40%. If it went slightly lower, I had it set to charge immediately to 40%, then top-up to 60% overnight. Charging was done at 5 amps (the minimum possible),
On long trips, I would charge up to just over 80% at the fast chargers - the 'knee' of the charging curve for that EV - shown when the power output of the charger dropped quickly from the maximum.
When I traded it in, the battery was still showing full range (in a 9-year old car), so it had not used up all the built in (hidden) flex-capacity - in other words, it still had at least 80% real capacity.
I'd like to do the same with the MG5, which doesn't have an easy built-in capability to charge at a maximum of 5 amps - you can set the 'granny-charger' to do this, but not the car's main system, and my wall charger is not sophisticated enough to do it either.
The Energy Management display of the MG5 highlights a range between 40% and 80% to keep the battery in good condition. Does this mean that optimally, the battery should not drop below a 40% SoC, or be above 80% (for long)?
What is the best SoC to keep the battery at? My understanding for Lithium-ion cells (which could be laughably wrong) is that charging them to cycle a close as possible to the 50% level allows for the most recharge cycles - so charging to 60% overnight, doing a daily drive down to 40% and recharging to 60% overnight is about the best you can do - but I'm happy to be guided by an expert (with references/Internet links where possible).
Some publications claim a difference between Lithium Iron Phosphate cells and Lithium Nickel Manganese Cobalt (NMC) cells, in that the former tolerate being charged to 100% far better than Lithium NMC cells, but Lithium NMC cells have better cold-weather performance. I don't know which chemistry the MG5 batteries are, and would like to find out - anyone know how?
At the moment I'm getting a long-term efficiency of 14.3 kWh per 100 km (which is 7km per kWh, or roughly 4.4 miles per kWh) (The old EV allowed me to switch between kWh per 100 km or km per kWh, which I prefer. It doesn't seem to be possible to switch similarly in the MG5, but my mental arithmetic is getting better.) This means that at 50% charge, on the 'Eco' setting, it claims a range of 230 km. Given the rated range of a 100% battery is 380 km, that looks like a good result. I doubt it will last into winter, though.
So, what's the best (practical) regime for caring for the battery?
Balance Charging - a few questions
A few EV noob questions I have had my phase 2 Trophy for about 2.5 months now, and as it is owned not leased, I am keen to keep the battery in as good a state of health as I can. With that in mind I have been cycling it between around 20-80% as per recommended practice. The thing is that we...
