Bam Bam
- Feb 6, 2024
- Oxfordshire, UK
- MG4 (2022-2025)
With a PHEV I wouldn't charge it back up to 100% every time you do a short journey.Just reading up on this (Google is your friend!) and it seems most 'experts' are still recommending that, to maximise the longevity of your LFP battery, you limit charging to 80%, only charging to 100% every now and then to equalise the battery.
Work out your usual journey distance and when it drops below that range charge it up to 100% the night before your next drive. Then it won't be sitting at 100%, or cycling between 75-100% which is the issue that has been raised in the research you've probably seen.
