Home charging puzzle!
mg2000
Rochdale England
I’ve recently bought an MG4 Trophy Long Range and an Ohme Epod home charger. The car display says the car is not charging above 5.7 kW, but Ohme customer support have logged onto the charger and tell me that the Epod is charging at 6.5kW! Ohme say I should see if there is any way to adjust / recalibrate the car display! I don’t even know if this is possible!
Has anyone out there experienced something similar and can anyone suggest a solution?
Thanks!
Mark
The onboard charger (assuming you have a MY23 Trophy, the one with the rear wiper) is rated to 6.6kW charge rate. I recall reading that the Ohme reads the charger capability and sets that as the maximum charge rate, so you'd always get less charge rate into the car due to losses. (The numbers you've stated seem fairly normal in terms of losses).
The Ohme should really let the car control the charge rate (like my Wallbox Pulsar Plus does ... I get 7.2kW in the Wallbox app and 6.4 to 6.5kW in the iSmart app).
As above, Ohme thinks the MG4 can only charge at 6.6 kW so tells the car to charge at that max rate when it sets the schedule.
They get the data from EV-database.org and the speed there is wrong, along with several other cars. Try changing your car in the Ohme app to one that has a higher speed and a similar capacity battery. The closest match I can see is Smart #1 Pro+ it says that can do 22kW so your charger should go flat out as it can’t supply that fast. The rest of the difference is just charging losses.
I keep meaning to try this myself but haven’t gotten around to it. Changing to an ID.3 in the app should work too but the battery capacity is a bit smaller or much bigger depending which model so could get some odd schedules. I also haven’t bothered yet as by charging slower you get more cheap rate slots outside the normal cheap rate period!
Better still talk Ohme into setting the MG4 profile up with the actual rate the car can charge at but doubt you’ll get anywhere with that.
The speed there is correct (for a MY23 car - it's wrong for a MY22 LR car) ... the problem is that Ohme are setting the charge rate the same as the car's capability rather than setting it higher to account for losses. :)
Thanks for the comments so far! I’m still new to EV ownership, so what are ‘normal losses’? Thanks
About 10% seems normal according to what people report on here.
Lost to heat and converting AC to DC.
I'm wondering if losses will be higher when the temperature rises. Electrical resistance in metal rises with temperature after all.
Still, even 20% is a lot less lost than a combustion car (which is 65% or more lost to heat and friction)!
I think we are saying the same thing in a different way? EV-database has the rate the onboard charger can actually charge the battery not the power it can draw.
By commanding the on board charger to charge at 6.6 kW it doesn’t actually draw the maximum power (effectively slowing down by the predicted charge losses).
Or do you mean there is a version of the car that can only draw 6.6 kW and that’s the figure ev-database has?
My ZJbeny single phase wall charger has a maximum output of 32 amps at 230 volts which is 7.36 kW. Voltage can legally vary + 10% to - 6% (253,3 volts to 216.2 volts) so I often see voltage of 240 during the day when there is a lot of solar infeed so that means at 32 amps of current the charger can feed in 7.68 kW to the car.
The cars charger shows 6.6 kW going in to the battery when the charger is delivering 7.0 kW, a loss of 400W. This is 5.7% lost to heat, resistance and other factors.
The SR car (all versions) and the MY23 LR/XP cars have a single phase onboard charger rated at 6.6kW output. (i.e. charge rate into the battery). The MY22 LR cars have a 3-phase onboard charger rated at 11kW, but which gives 7kW from a single phase source.
So what I'm saying is that the Ohme is reading ev-database (I have no reason to doubt your assertion on this) and then setting the maximum output of the Ohme to 6.6kW, rather than just letting the car determine what maximum charging rate it wants to use. :)
Yeah we agree then.
To be fair to Ohme, it’s a bloody good bit of technology. They don’t let the car decide so they can create some utterly bonkers schedules to help balance the grid and charge when it’s cheaper for them. The car has ultimate control though, as I discovered when I had my ID.3 that had a software bug that throttled all charge speeds in half.
A typical charge with my Ohme will vary speed all over the place and often have multiple pauses. Yet it’s always within 1 or 2% of the charge I requested at the given time.
The biggest bonus is you aren’t confined to the cheap rate period. You can set the Ohme app to add whatever you need (say 30% by 8pm) and plug in at, say 11am and it will come up with some bonkers schedule and be ready within 1 or 2 % at 8pm with all that extra cheap rate electricity!
The car always has the final say as to what goes in to the battery. Wall chargers are not chargers at all, they are Electric Vehicle Supply Equipment (EVSE)s. The charger is in the car itself and that consists of an inverter to change AC current to DC current and software to determine how much DC current it will allow the battery to accept. The maximum output to the battery through the inverter is 6.6 kW.
You can set the maximum current on the Charging screen in the infotainment system as well. There are 3 steps but most EVSEs allow you to determine the level of input current in AC to the inverter. I can adjust my EVSE from 1 amp to 32 amps.
Of course intelligent EVSEs can make changes automatically on the fly by knowing the rates and timeframes as well as output from solar systems etc.
Ohme app/ePod charger: Bumping this old thread as I have a MY22 MG4 SE LR and only ever see a max of 6.4kW charge power when charging using my Ohme ePod. Has anyone tried setting a 'my vehicle is not in the database' EV up in the app to overcome this? I have set up a second EV in my app with the details: brand - MG, model - MG4 SE LR, battery capacity 64kWh, max AC charging 7.68kW and max range 279 miles (guesstimated), but haven't tried it on a charging session yet to see if it makes a difference to the charging power because I don't want it to cause any glitches with Octopus Intelligent Go charge session recording, but...
The standard settings for the MG4 SE LR in the Ohme app already seem to cause some glitching at the Octopus end of things though - using Home Assistant I can see that the useable battery capacity of 61.7kWh that is listed in the MG4 SE LR model details when you use the EV model picker in the Ohme app shows up in Home Assistant as the actual battery capacity, so this might also be making the charger target % a slightly lower amount of kWh total supplied than is actually required, which might explain why it's sometimes around 1% short of target on finishing charging. :unsure:
Changing the car in the app or doing any other change will make no difference - you are restricted by the car's on board charger.
I don't dispute that - my car is a 2022 model year SE LR with 3-phase charger on board so it's capable of 7kW from single phase. I can confirm that with a custom EV set up in the Ohme app with the max charge power set to 7.7kW (next step up from 6.6kW in the preset options, which is what the preset MG4 LR defaults to), I'm now seeing max charging power of 6.9kW from the Ohme at 32A. And with the battery size set to 64kWh I'm now seeing good agreement of the battery % added as reported by Ohme and what I calculate using the data in Home Assistant. 👍
Another thing to consider is charge losses. The Ohme is putting AC into the car but the car is converting it to DC to charge the battery.
As a rough rule of thumb, there is a 10% loss in the conversion. Ohme / Octopus seems to gotten rather good at accounting for this and now seems to add extra charge for it but it’s probably a bit of a dark art. The losses are why the rate the Ohme app and car app show different charge rates.
Which incidentally is a reason why charging from home solar isn’t as good an idea as it sounds. You end up converting solar DC to AC then AC back to DC, which can result in 20% losses.
Yes, I'm only looking at what max power the Ohme charger is delivering at the moment, as reported by the Ohme app and picked up by the Ohme integration in Home Assistant. Changing the EV profile in the Ohme app from the preset MG4 LR (which has 6.6kW max power) to a custom EV profile with a max charging power of 7.68kW has increased the maximum charging power reported by the Ohme app from 6.4 to 6.9kW, which suggests that it's now being limited by the 7kW maximum that my car's onboard charger will accept. I'll look at the charger power the MG app is reporting next time I charge.
I think your theoiry might be sound. With the Octopus app set to the MG4 the max charge rate I have seen in the MG app was 5.8kw, I changed the car to a Smart #1 pro+ and the MG app now says 6.2kw, 6.7kw in the Hypervolt app.
I will see how it goes.
I have not looked recently but last year the App (version not known) showed 200W more than that showing in the car whilst charging with the car powered up. I assume the App was reporting DC power to the car not power to the battery. Should not be too different if the car is not powered up.
    Votes: 1,052 77.9%
    Votes: 204 15.1%
