How long should the 12 volt, battery last ?
Laurence Brown
Malvern
We have had ther MG ZS for 40,000 miles and I am worried the 12 volt, battery will suddenly let us down - where and when we least expect it to.
When driving the meter still shows a healthy charge, but really, a nearly four year old battery still functioning as if it were new?! The longetivity pleasantly surprises me.
Do you put yours on charge?
I think we did once overnight.
Has anyone experienced a dying battery please?
And many more.
We have an MG ZS EV '70' plate so over 4 years old now and 22k miles. I've never had any problems with the 12V battery.
I have fitted a Bluetooth battery monitor to keep an eye on things and alert me to any problems. They're £30 on Amazon.
Watch Mr EV's video to see what it's all about - Battery Monitor. and the one I bought is here.
Here's my data for the last 15 days (well, I haven't sync'd it for a few days but you get the gist).
I think that is too much information! Dropping to 12V regulary is not what I would like to see!
I really like the 12V monitoring capability of a Victron 75/15 mppt, shows 30 days history with daily highest & lowest voltages.
I think it's good practice to change the 12V battery at the first sign of weakness, as others have stated, carry a lithium jump starter to get you out of trouble.
If you're using the car regularly, the regular charging of the 12V battery provided by the car will help keep it healthy and lower the rate of sulfation/capacity loss.
Our last car was a Honda Diesel. We bought it new and it was registered in November 2009.
We found out it was a 2007 build and had been hanging around in the dealership network. Consequently, the battery was goosed, although, this wasn't mentioned when we bought it. But I negotiated some "cash back" to replace it, as it kept letting us down.
I bought a Bosch S6 Stop/ Start battery from Tayna which was absolutely amazing and did the car proud from around 2 months old until after we got the MG4 in mid 2023. In fact we sold the car with it still going strong. By this point, the car had done 175,000 miles, nearly all of them with the Bosch battery.
There is no doubt there are good batteries and bad batteries, often down to how they were treated before use in a car. If there is any doubt about any particular battery, best to just change it for a new one. I also recommend Tayna who do next day delivery.
I had to change my 12V battery after 4 years or so. ZS EV CV70.
I suspect the EO Charger might have something to do with it, by leaving the car switched for a long period, The Charger went *its up at the same time. MG dealer charged me £200+ for a replacement...
I generally seem to manage 7 to 9 years. I use a battery conditioner if the car is idle for long periods.
However when I changed my Morgan last July the car had sat at the dealers for 9 months. The dealer told me they kept their cars on conditioners . Six months later at just under 2 years old it failed.
I didn't think it could be the battery so called out the AA. Their guy told me AGM batteries, which this was, often fail at 2 years. I too went to Tanya for a replacement.
I would recommend a Ctek battery keeper... the .8 amp will work just fine and put it onto the battery and leave it on for as long as you can every few months. I kept a battery on an Astra going for 16 years, it had been my work car for about 10 years and done 80k miles after that it was little used but the battery keeper would bring the green telltale back on the battery even if left unused for 3 months. I would leave it on for a week or more to work its magic!
My 12V battery lasted 2.5 years and had only done about 21k miles.
Yes my battery died on me last weekend.
I could not start the car at all and had to ask for a lift. I have had this car MG ZS from April this year. I don’t drive much and when getting in touch with the MG garage they are saying that I don’t drive the car enough. How can I charge the battery without driving it or is there something else that is using the battery? Help please.
You could buy a trickle charger with automatic shut off , that will save your battery if not using the car enough especially if only doing short journeys. Some batteries will last about five years depends how much the individual is using the car ?
Smart trickle charger will only charge when your 12 volt battery drops below a certain voltage that would be the best for you . When a car is running the alternator will charge the battery between 13.5 and 14.5 obviously if doing short journeys it might not get charged as high as that especially if you have lights heated seat etc on .
I don’t drive the car enough how can
I charge the battery without driving it or is there something else that is using the battery. Help please.
I bought a CTEK battery charger during Covid when I wasn't driving my car at all. It may have been overkill but I just connected it to the battery and plugged it in for a few hours (or a couple of days) once a month or so. There are other brands (I think Noco are pretty good too) that offer smart chargers that will charge, trickle charge, maintain your 12v battery. All you have to do is connect it to the battery and plug it in. This way you can maintain your 12v even if you don't drive the car.
I have a CTEK that charges my camping battery and used to keep the battery topped up when I wasn't driving regularly.
When the battery in my Diesel Octavia got goosed, it did a fantastic job on the de sulphation cycle and brought it back to life. It was winter and snowing and the battery was showing 1.2V.
The CTEK won't charge unless it's above 2V, so I got the hairdryer on an extension lead and after about 20 minutes, it rose to 2.1V and then started charging.
But by the end of the charge, it was almost as good as new.
I was under the impression that the 12V battery was charged along with the traction battery?
If the battery only lasted about 6 month I would be hitting MG up for warranty replacement.
My ZS EV has only done 4,500km in the 9 months since buying it new in November 2024 and have had no problems even only using it once a week.
I think the 12 volt battery is covered under warranty for the first 12 months. The EVs battery is charged when you plug it into the mains . The 12 volt battery will be charged from the alternator unless you have a hybrid and that's different again regeneration through braking and engine starting up to charge traction battery etc.
BEVs don't have alternators on my zs ev the 12 v is charged from the hi voltage battery. You can see it doing this on the app when parked.
Nevertheless I have ctek comfort connectors on the 12v and charge it from time to time .
