sky0000547
- May 25, 2021
- Location
- South Yorkshire
- HS PHEV
Off topic but noticed you have a dash cam, 522CW? I will get a dash cam for mine when it arrives but is it hard wired? (I cannot see the wire as it is probably black on black) and if so the cable run?
It is 522GW. The dashcam is hardwired into the fuse box. You won’t see any cable run as it all hidden. The cable runs up from the camera and hidden in the gap between the plastic casing of the rearview mirror and the headlining then just enough into the headlining to the driver’s A-pillar. Remove the rubber seal and hide cable inside the A-pillar straight down to the fuse box. It is actually quite an easy job.
