Lucky5
- Feb 5, 2021
- Location
- Eastleigh, Hants
- Not an MG
Hi All, just to update on this issue.
It was still dead this morning with no USB power so I thought I would check the fuse first and after nearly setting fire to the manual with a magnifying glass before I could see which fuse it was managed to pop it out and it was intact. Oddly it was 20A fitted at factory and not 15A as per the manual.
On putting it back in everything booted up and is working normally so the head unit just needed the permanent 12v supply removing in the same way as removing the 12v battery lead as suggested above. In future I will do that as I already have a 10mm spanner in the car but this time as I had no USB power I thought worth a look at the fuse first. Thanks for the advice guys. This is the first glitch in 5 months and 3.5k miles so hoping the software update for the 5 head unit comes in time for first service next year.
Lovemyev - My nickname for all my adult life starting when I was 18 in my first job has been ”lucky” and not for that reason sadly! If something is going to go wrong then it will for me!
ATB
Mark
ATB
Mark
