I'm just searching the manual now @Rei will let if you know which numbers I used, but if you look carefully at the pic I've ringed,Thanks for the great photos, very helpful. I might have a go at taking the front off like you did.
So which fuses are which? Permanent and switched I mean.
You need to give it a good tug, there are two phillips screws to the right hand side, under to remove before the cover can be yanked off, feels pretty brutal, but nothing broke!I'm just searching the manual now @Rei will let if you know which numbers I used, but if you look carefully at the pic I've ringed,
It's the top empty fuse F10 which is permanent live and the other 3 pin, switched is one of the 3 x 3 pin fuses 44 or 45, but just put a meter across them to make sure I've remebered the correct way around.
Just amended to 44 or 45, but please check, but you definitely can turn off the ignition (funny word for an EV) and sit in the car, making it a lot easier.
Thanks, I think you are right, F10 is permanent live. I think I'll have to take the front off to get to the other one. F44 and F45 make sense.
Does the front part just clip in like the side part, once you remove that bolt?
I will enquire of the said "jelly" stuff @securespark, just in case at 77 I am lucky enough to need it (as a cable draw through assistive product of course!) are there other usess then?As a spark, I would advise against using vaseline. Being petroleum based, it can break down plastics, including PVC.
Odd as it would seem, I would use KY Jelly (other brands are available). It's water based and won't harm the cables.
There are similar products made for dragging cables in, but they come in huge containers and they can't be used for other (ahem!) purposes when you've done the job.
1. Remove too-tight rings. Better than butter, and cheaper too! Have you priced butter recently? Robbery!I will enquire of the said "jelly" stuff @securespark, just in case at 77 I am lucky enough to need it (as a cable draw through assistive product of course!) are there other usess then?
Will be fun asking for it at the chemist.I will enquire of the said "jelly" stuff @securespark, just in case at 77 I am lucky enough to need it (as a cable draw through assistive product of course!) are there other usess then?
