Ruislip Resident
Oil and gas industry sponsored media outletWhere did he get that from?
Insert oil and gas industry sponsored right wing media outlet here . . .
Oh, I can't get an EV as need to travel more than 100 miles before recharging.
I get nearly 300 miles, where did you get that from?
The misinformation is rife!
Yes, and likely a direct result of the horseshit information published, re-published & 'developed' on social media. Like this story here, some better reserach might be required vs. just continuing to re-publish the stupid story ....I had a friend who was absolutely convinced that if an EV driver wanted to drive beyond the range of his car, he had to take a hotel room and charge the car overnight. When I said no, I drove all the way to Brighton (from Scotland) in a day with three 30-45 minute charging stops, he showed me an information sheet about a Tesla which said it took 8 hours or something like that to charge on a "fast charger". Like he didn't believe me when I told him what my (SR) car was actually capable of and had actually done!
So I explained about DC as opposed to AC chargers, and batteries that charge so fast you scarcely have time to snatch a coffee, and he went completely quiet. I didn't even get a response.
People are weird.
All true except the nonsense comments at the end.Yes, and likely a direct result of the horseshit information published, re-published & 'developed' on social media. Like this story here, some better reserach might be required vs. just continuing to re-publish the stupid story ....
There's another one getting around just recently (I will not contribute to the BS by re-publishing), however it goes like this (together with the findings by people who took the trouble to followup & do some research /fact finding):
It goes that BYD EV batteries are catching on fire everywhere in China & its a huge disaster /cover-up everywhere, yadda, yadda ... The thing is that in the video purportedly showing this, some indentified that the car was in fact a deisel Range Rover & even followed up on the registration plates ... futher, the site reporting this was from an 'American' in suit & tie (dressed up in studio to appear 'authoritative), but in fact a background check was run on him & turns out he's a disgruntled South African who lived in China for a while & didn't like it so much ...
Also clearly a racist tone which tends to happen a lot when Anglos start talking about the (current) 'other'.... Seems that the West is increasingly upset (check out Germany & the US for example). and only recently starting to notice that the Chinese are walking all over this EV manufacturing, suppliing most companies, owning or part-owning many Western companies & even more infurating, actually doing a pretty good job of it.
We need to do better than lazy social media, & even worse, circulating the stuff. Clearly, the disinformation war is becoming increasingly dangerous - from Brexit, to Trump, to the recent Australian referendum (not to mention a range of swing-ultra right elections in the EU) - far too many actaually belive what might be published 'by anyone' on a platform like LazyFace.
The ordeal, which happened at about 4pm last Friday, October 20, comes amid reports of MG ZS > models in other parts of the country having brake failures.
Aren't braking systems dual circuit?Happened to me once on a Jaaaaaguar. New rear tyre installed, the mechanic had left the flex hose in such a place that it was fouled by the tyre. Gradually wore it away until the hose split and fluid left the system. Long brake pedal that day.... I used the handbrake.
Do you have any source for that? In my experience, regen happens when you let off the accelerator. When you apply the brake, regen may assist in braking, but the actual brakes will also engage.Well, the MG4 at least as the ability to disconnect the brake pedal from the wheel circuits - that is what it does when regen is enabled, otherwise the brakes would always engage along with regen.
The master cylinder is disconnected from the wheels and switched over to a dummy "load" whilst the car uses regen to brake. Once the dummy load exceeds the capacity of the regen, the master cylinder is reconnected to the wheels for additional normal braking.
It's not inconceivable that this could "go very wrong" is it?
Why would "brakes always engage with regen"? There is no technical reason for that.
Normal Braking During normal braking, the shut-off valve is energized and closed, and the brake fluid cannot flow to the caliper; meanwhile, the pedal simulator solenoid valve is energized and opened, the brake fluid flows to the simulator, and the driver's static pedal feel is provided by the pedal simulator. The master cylinder displacement sensor and the master cylinder pressure sensor monitor the driver's braking request at the same time, perform calculation through the built-in software model, and send the required pressure buildup request to the brushless motor. The brushless motor works to build up pressure for the four caliper wheel cylinders.
Regenerative Braking During regenerative braking, the shut-off valve is energized and closed, and the brake fluid cannot flow to the caliper; meanwhile, the pedal simulator solenoid valve is energized and opened, the brake fluid flows to the simulator, and the driver's static pedal feel is provided by the simulator. The master cylinder displacement sensor and the master cylinder pressure sensor monitor the driver's braking request at the same time, and perform calculation through the built-in software model. If the capacity of the motor meets the braking requirement, the brushless motor will not work.
So, I was wrong, even normal braking is "simulated" drive-by-wire.Failure Braking Mode When the electrical module fails completely, the shut-off valve is normally open in the power-off state. The driver depresses the pedal to generate the braking pressure through the TMC, which builds up pressure for the four caliper wheel cylinders.
It does sound rather a complicated system when simplicity is often the key to safety.
