iSmart
I had exactly the same with mine. It showed window open and when I checked one rear window moved up slightly even though it looked closed and the message cleared on refreshing the app.
Hmm, interesting. I have the same notification on mine. Can't be more than a couple of millimetres though, looks fine from the house. I'll check it later, not going out there just for that...
Well, I tried refreshing the screen, still showed the windows open.
Went out to the car, made sure the windows were all closed, went through the window reset procedure just to ensure it knew where the top was. Now the app says it can't connect.
MG's connectivity really is crap.
After an hour and a half I tried again, the app connected and said a window was open...
Interesting. As in my post above my 'windows opened' text appeared to be random. Last 2 app starts it did not display at all. So I unlocked the car powered it up and opened the driver's window and locked the car. On starting the app I got the'window opened' text. left the App opened and closed the driver's window; refreshed the app and the text disappeared. The same happened for all 4 windows.
So, it appears, the 'windows opened' text is accurate for my MY22 Trophy so it may be type dependent as @siteguru's tests did not give the same results.
I tested mine by locking the car with the lock button on the inside of the driver's door and then opening and shutting various windows, refreshing the app each time. The app reported the state of the windows correctly every time. Mine is a 2022 Trophy.
Mine is also reporting the window state accurately - when the app actually refreshes that is, it was v. unreliable this afternoon. It's handy it shows the time of the last refresh on the app now.
    Votes: 967 77.7%
    Votes: 185 14.9%
    Votes: 93 7.5%
